Issue with refresh token
Hi community,
I’m working on script automation for our Rest API and I should renew my token evrey 30 minu using a refresh token, but when i generat a new token using powershell the new rferesh token include a specific caractère “}” that block my process to generat news token and auhtentification.
Hve you any idea to fixe this error or to filter caracter when I refresh my token?
Thank you.
Jon Vengust
Hi DELEL,
Hope you’re doing well.
Please bear with me as I’ll look to investigate this matter internally for reproduction and insight.
  • May 2, 2025
Thank you for relplay.
I would mike my Rest API 100% automatic using powershell comamnd.
For that I should refresh my token every 30 minutes but I conclud that all refresh token generated by script contain the specifc carracter } that bloked the process to get a new token using the refresh command token.I have this issue every time that i used a script method. So can you help me to resolve this problem, because my object it's using an automatic whay 100% to turn my rest API and I don't wont return to portal for generat a new token and a correct refresh token .
Jon Vengust
Hi DELEL,
Thanks for the context.
I spoke with DEV on this matter and they’ve advised to pursue this further through a support case. Please have one raised and you can private message me the ticket number to take it from there.
