Issue with schedules after migrating to plan
  • March 15, 2024
  • 59 views
to backup our vcenters in liked mode, we have a script that connect to each esxi that host the vcenter, shutdown the vcenter, perform the backup through Commvault api, then start the vcenters.
there is no schedule policy on these subclients
adfter migrating to plan,
there is a schedule policy inside the plan.
on the VMgroup (ex subclient)
How can I disable the schedule to avoid this VMgroup backed up automatically by Commvault and let the script schedule the backup (ansible)  ?
Best answer by Collin Harper
Hello @Bloopa
The schedule should get disabled as part of the Schedule → Plan Conversion. Plans use their own RPO (Recovery Point Objective). You can simply delete the RPO’s defined in your desired Plan.
Thank you,
Collin
  • March 15, 2024
Hello @Bloopa
Thank you,
Collin
