Issue with WebConsole – Reports and SLA failing after failover
  • March 30, 2026
  • 103 views
hello
We are experiencing an issue with the WebConsole on our Commvault environment following a failover.
Failover windows cs to linux cs
Environment
  • Commvault version: 11.40.26
  • CommServe OS: Linux
  • WebConsole / Command Center hosted on: linux
Issue Description
  • The WebConsole is not functioning correctly.
  • Scheduled reports and SLA reports are failing.
  • jobs are working without any issue.
Observed Behavior
  • Access to Command Center (/commandcenter) is working (HTTP 200).
  • Access to WebConsole (/webconsole) returns HTTP 404 (Application Not Found).
  • Reports fail with the following error:
    • "Failed to get the list of command centers"
    • "There is no WebConsole available to proceed further"
Logs (relevant excerpts)
  • scheduleReport.log:
    • GetWebConsoleURLList() - There is no WebConsole available to proceed further
  • JobManager.log:
    • Failed to get the list of command centers for web server id [0]
  • Apache logs:
    • /commandcenter → 200
    • /webconsole → 404
Actions Already Performed
  • Verified that WebConsole and Command Center components are installed
  • Restarted Commvault services
  • Performed repair via cvpkgadd
  • Verified Apache and WebServer services are running
  • Confirmed WebConsole binaries are present on disk
Current Assessment
It appears that:
  • Command Center is operational
  • WebConsole (legacy UI) is not deployed or not registered properly
  • No Web Server entry seems available from CommServe perspective (web server id = 0)
Request
Could you please assist with:
  • Verifying the Web Server / WebConsole registration in the CommServe database
  • Providing the correct procedure to redeploy or re-register the WebConsole
  • Confirming if this behavior is expected after failover and if additional steps are required
Please let us know if additional logs or diagnostics are required.
Sougato Roy
hello
Environment
Issue Description
Observed Behavior
  • JobManager.log:
  • Apache logs:
    • /webconsole → 404
Current Assessment
It appears that:
Request
Hi ​@mahmoud Hatira ,
Please refer to Web Console Deprecation: What Customers Need to Know article and check if that helps with your issue. ​@Pradeep Could you please assist here?
Thank you,
Roy
