Answer
iTeamsUseProtectedAPIs vs. client1_iTeamsUseProtectedAPIs
  • August 11, 2021
  • 165 views
Forum|alt.badge.img+8
I would appreciate some clarification / confirmation here. What is the difference between the iTeamsUseProtectedAPIs and the client1_iTeamsUseProtectedAPIs additional settings?
Does "client1” needs to be replaced by something :relaxed: ?
Is it correct that these additional settings must (can) be placed on an access node alone (e.g. not on the CommServe)?
Best answer by Damian Andre
Hi, I can use an access node for Teams backups of different tenants, who don't necessarily backup Exchange Online.
Ah yes - prior to fr22 I believe you needed mailbox confit to backup teams but now there is a dedicated agent. In this case you would use the teams virtual client name for the additional setting
Hey @iConsultant,
I need to further verify but I think iTeamsUseProtectedAPIs is access-node wide (will effect any client with backups running through that proxy), whoever as client1_iTeamsUseProtectedAPIs you can narrow it down to jobs associated with a specific client even though the access-node is processing jobs from multiple clients (in this case client1 would be renamed to the name of the client). This would be important for a shared infrastructure / MSP scenario.
Makes sense that it goes on the access node and not the commserve
  • Certified Expert
  • August 12, 2021
Hi @Damian Andre, In the MSP scenario there could be 1 Client (access node) which could serve several (end) customers. I am not sure how renaming client1 to the name of client would fit in, unless (now I think about it) with client here something as the name of a specific Office 365 App would be meant.
Correct but the client will be the virtual client ( Exchange Mailbox client) not the physical access node. Just trying to get confirmation.
edit: confirmed here in this KB: https://kb.commvault.com/article/67692
  1. To run backup for a specific client only, create the additional setting client1_iTeamsUseProtectedAPIs, and set its value to 1.
  • Certified Expert
  • August 13, 2021
  • August 13, 2021
