JOB Controller Operation
  • May 27, 2024 11:12 PM UTC
  • 47 views
Forum|alt.badge.img+2
From the CS GUI, the JOB Controller Operations has ‘VM Admin (Backup).
We are using 11.28.44 FR and this is newly created subclient from  VM backup.
Is there a fix for this?  Appreciate it.
Erase4ndReuseMedia
If I’m following you correctly, I think you’ll want to check this setting:
CommCell Console > Control Panel > Job Management > General tab: Show Individual Virtual Machine Jobs in Job Controller.
  • May 28, 2024 12:55 AM UTC
Thanks..you meant ticking this will revert back to normal ‘Backup’ display operation?
appreciate it.
Erase4ndReuseMedia
Take a look at this for more information:
Jobs and Job Control for VM-Centric Operations (commvault.com)
  • May 28, 2024 2:46 AM UTC
Thank you for your reply and useful tips.
Appreciated it.
