Job Statistics Report Commvault Store issue
  • July 28, 2021
  • 152 views
Heath
Apprentice
I recently downloaded a report called Job Statistics from the Commvault Store and when I import the report it doesn’t seem to link up with my system and shows no information.  I have had this with another performance report.  I don’t see anything in the store that tells me I need to change anything.  Has anyone had this issue with reports?  Am I doing something wrong?  Any help would be great.
In the store its called Job Statistics - Release Date Aug 2, 2019 - Version 1.1.2.3 - Author Commvault
Thanks again in advance for any help with this.
Best answer by Juan Rosas
Hi @Heath
The Job Statistics Report need some requirement that might not be enable or configured correctly in your environment.
If the report is looking like the image below, please check the log named CustomReportEngine.log
In the log you might see a line(s) similar to this to the one below, if that is your case
the Index Store and/or Log Monitoring Roles are not enabled/configured
I will suggest to open a case with support to investigate further
10252 68812 07/28 11:06:57 : SEVERE: failed to retrieve data for datasource [], dataset [All Resources], user [XX\username], error [commvault.web.logmonitoring.engine.LogMonitoringException: No cores available for selected policies]
Forum|alt.badge.img+5
  • July 28, 2021
Hi @Heath
Heath
Apprentice
  • July 28, 2021
Thank you Juan, that is what I see, and I do have that error.  I will open up a case.  Thanks again for the help.
