Jumbo frame affect
  • March 22, 2022
  • 1195 views
Forum|alt.badge.img+13
Hi Team,
Does jumbo frame mtu 9000 affects to backup/restore performance positively ?
Best Regards.
Best answer by Orazan
Good morning. Jumbo frames can improve performance in some situations, but that depends mostly on your network architecture so it is hard to say exactly.  Switches and routers must support jumbo frames end-to-end on the data protection network in order to avoid fragmentation.
Forum|alt.badge.img+18
  • March 22, 2022
