Kubernetes Restores in Namespace Default
  • Jun 20, 2024 8:00 AM UTC
  • 41 views
Hello Community,
I am facing problems at restores incl. “unconditional overwrite” option into NS Default. Even a Inplace restore back into the Default NS as well as an out-of-Place restore into Default NS. Every other destination is working for restores. Do anyone know restrictions or is aware about this?
I have problems restoring including the “Unconditional Overwrite” option to NS Default. Both an in-place restore back to the Default NS and an out-of-place restore to the Default NS. Every other destination is working for restores. Does anyone know or are aware of any limitations?
Hello @Pascal Zach,
I had a chat to my internal client guru and he advised that it is very odd and not recommended to restore into the default name space unless you are doing a cluster rebuild.
He also advised you should be able to do this if you really wanted to. So if you truly want to do this restore the recommendation is to raise a support case to look over your errors you are getting to see why it cannot be achieved.
Kind regards
Albert Williams
