Laptop Edge Monitor Start asking credential while saving a file
  • May 26, 2022
  • 97 views
Good Morning,
a colleague encountered a credentials request from the commvault edge monitor while she was saving a pdf file. Is it a normal behaviour ?
Thank you
Ilario
Best answer by Dmitriy
@Ilario check this option “Turning the privacy setting off also requires you to enter your password.”
https://documentation.commvault.com/11.24/expert/4486_control_administrator_access_to_your_data_01.html
  • May 26, 2022
  • May 26, 2022
yes @Dmitriy , it is enabled on the LDAP external authentication server.
  • May 26, 2022
