Linux MediaAgent Mount Path is inaccessible
  • January 17, 2023
  • 974 views
Forum|alt.badge.img+2
Hi all,
I’m currently running commvault 11.30.23.
Decided to give a try with Linux Media Agent Disk Library
My setup is the following:
RHEL 8.6 fully patched
Roles:
MediaA
Index Store
Index Gateway
Index Extractor
FS core
FS
Virtual Server
Mount points created with lvm.
1x for backup with 500 GB
1x for ddb with 250 GB
/dev/mapper/vgbck1-lvbck1  500G   68G  433G  14% /commvault-lvbck1
/dev/mapper/vgddb1-lvddb1  200G  2.6G  198G   2% /commvault-lvddb1
and the / with 100 GB
Also Ransomware protection is enabled.
What happens is, after some backpus the disk library goes offline.
And then the following message is displayed:
Offline (Mount path is inaccessible. Check the following.\na. Is the mount path visible to the operating system on the MediaAgent machine.\nb. Is the username/password correctly entered.\nc. Does this user have read/write privileges to this mount path.)
If i restart the services or the server, it stays online for a few minutes and then goes offline again.
This is a LAB environment, I’m testing before I deploy the server to production.
Any help welcome
regards
  • January 18, 2023
Could be a few things but difficult to tell without logs. Is SELinux disabled? that could be preventing a periodic check
Otherwise cvd.log or cvma.log may have more details on why it becomes inaccessible.
  • January 18, 2023
disabled SELinux, also firewalld service disabled for testing purposes, same issue, i’ll have a look at the logs.
the strange thing is, i’ve deployed a new linux media server following the same steps, and this one is working fine
Forum|alt.badge.img+20
  • Challenger
  • January 18, 2023
hi, simple dumb question but, as this looks to be a VM, and it goes offline during the backups, is this server not included inside the VM group that you are trying to backup ?
2nd question as I’m no linux expert, is about disks/luns used for DDB and for ‘backup’ : are you sure it’s not hosted on the same ? don’t you have DDB backup initiating a snap of volume for the DDB backup ?
But, as you mention it, it’s strange that the 2nd you deployed the same way is working fine ;)
  • January 18, 2023
Hi, yes it s a VM, VM itself(MA) not in the backup job.
DDB on the same linux machine in a different partition/disk, no DDB backup performed.
