Live Sync configuration issue – can it be deleted and recreated from scratch?
  • February 27, 2026
  • 46 views
I am having an issue with a Live Sync setup I created for a customer.
The installations on both the production CommServe and the standby CommServe completed successfully. However, after enabling Live Sync, nothing happened.
When I checked the Failover Process Manager, I could see the production server with a green status indicator, but the standby server did not have one.
I also noticed that the CommServeDR policy does not have any SQL subclient associated with it. The only thing I can see is instance001 from the production CommServe.
Later, I realized that the entire configuration was done without TCP ports 8405 and 8408 being open between the two CommServe servers.
My question is:
Is it possible to revert or completely delete this Live Sync configuration and recreate it from scratch after fixing the port connectivity?
Any guidance would be appreciated.
  • February 27, 2026
  • February 27, 2026
Hello , so the only way is to uninstall everything from the standby server….correct?
All the config entries will be removed from the production server? Command Center and Commcell console?
