Livesync Comserve through a Network Gateway?
  • March 27, 2023
  • 85 views
Forum|alt.badge.img+5
Hi! Wondering if it is possible to have a remote Commserve used in a Livesync configuation communicate back to the initial Commserve via a deployed Network Gateway or Network Proxy Appliance? All agents, media agents at site will use the Network Gateway but is it possible for the remote Commserve to communicate through it as well?
chrisknows
Explorer
Forum|alt.badge.img+9
  • March 27, 2023
Yes.
Getting it to work would require some creativity initially as you would have to create the configuration first and then apply the firewall definitions manually on the other side of the gateway.
I will elaborate later on my alt account : @christopherlecky
  • March 28, 2023
Thanks! Looking forward to details!
