LiveSync Failover Failure - Error 30:436 (SYSADMIN Role Validation Failed)
  • February 25, 2026
  • 302 views
Hello Team,
We are facing an issue during LiveSync failover in our Commvault Linux installation.
commvault version - 11.40.34
When we attempt to perform the failover, the CvFailoverLogShipping job gets triggered but fails with the following error:
Error code: [30:436]
Description: Instance validation failed: Insufficient SQL Server role. To configure the instance, the user [sqladmin_cv] must be a member of the SYSADMIN SQL server role.
Source: rhel1
Process: JobManager
Troubleshooting performed:
  • Verified the SQL login configured in Commvault.
  • Assigned required permissions, including SYSADMIN role, to the SQL user.
  • Revalidated credentials after updating permissions.
  • Verified permissions from the standby node as well; permissions appear consistent on both sides.
  • Despite this, the instance validation continues to fail with the same error.
create new user and assigned all required permission
Requesting assistance to identify why SYSADMIN role validation is failing during LiveSync failover.
Please let us know what additional logs or diagnostic information are required.
Hi ​@Aishwarya Upadhye,
Below error, mostly happens when the NT AUTHORITY\SYSTEM account being used does not have the sysadmin roles assigned. This has been outlined in the following documentations -> Configuring User Accounts for the SQL Server Agent and the KB Article -> 30:424 Failed to validate the credentials for instance [...]. Please make sure the provided user [...] has the sysadmin role.
Error Code: [30:424] : Description: Failed to validate the credentials for instance [rhel1]. Please make sure the provided user [SYSTEM] has the sysadmin role.
To verify/assigns the sysadmin role to the 'NT AUTHORITY\SYSTEM', please follow the below steps:
1. Open SSMS and connect to the CS Instance.
2. From the Explorer, Expand Security -> Logins -> right-click NT Authority\SYSTEM -> Properties -> Under "Server Roles", ensure that "sysadmin" role is selected for 'NT Authority\SYSTEM', if not check it and Hit on OK.
- Once the sysadmin role is assigned, navigate to the Production Failover Instance for Client 'rhel1_2', Under Accounts tab select Local System Account.
- Perform a check readiness of the Production Failover Instance and ensure Client & Instance both are ready.
- Once Instance is ready you may resume the job to see if it progresses.
Also, If you would like to use a different account which has the sysadmin roles, you can impersonate that user at the Instance level in the Commcell Console following below steps:
1. In Commcell Console -> Select the Click the Failover Client -> SQL Server -> Right-click on the Instance -> Properties.
2, Under Accounts tab, you can select "Override Higher Levels Settings", select "Impersonate User" and type the user account having sysadmin role on the SQL Instance  and click Ok.
Dheeraj
Dheeraj
Hello
Thank you for the detailed guidance.
As suggested, we verified the SYSADMIN role assignment for the required accounts.
Findings:
On the primary SQL instance, the required SYSADMIN permission was already assigned.
On the standby instance, the SYSADMIN role was not assigned earlier. We have now added the SYSADMIN role there as well.
After assigning the role on the standby server, we retried the failover process, but the same error persists.
Additionally:
We attempted to use impersonation with a different account having SYSADMIN privileges.
Since this is a Linux-based Commvault setup, we are unable to open the traditional CommCell Console.
Therefore, we performed the impersonate sql user from the Commvault Command Center (dashboard).
Despite verifying and correcting permissions on both primary and standby nodes, the failover still fails with the same validation error.
Kindly assist further on what additional checks are required from our end.
Hello Team,
This is a follow-up regarding the LiveSync failover issue reported earlier.
We have verified the SYSADMIN role permissions on both the primary and standby SQL instances and retried the failover process. However, the issue still persists with the same validation error.
Could you please provide an update on this case or advise if any additional logs or checks are required from our side to proceed with the investigation?
Looking forward to your response.
Dheeraj
Hi ​@Dheeraj Shetty,
Just following up on this issue. We verified the SYSADMIN role — it was already present on the primary instance and we added it on the standby instance as well. However, the failover job is still failing with the same error.
Could you please suggest the next steps?
Hi ​@Aishwarya Upadhye ,
Could you please confirm whether the scheduled CvFailoverLogShipping backups for the failover client ‘rhel1_2’ are encountering this issue?
If so, kindly share the SQLBackup.log from the production failover client ‘rhel1_2’, along with the JobManager.log from the CommServe after running a backup for the CvFailoverLogShipping subclient on ‘rhel1_2’.
Additionally, we recommend raising a support ticket for further investigation. Thank You!
Dheeraj
Dheeraj
Hi ​@Dheeraj Shetty ,
We verified that the scheduled CvFailoverLogShipping backups for the failover client ‘rhel1_2’ are encountering the same issue.
We attempted to upload the requested logs (SQLBackup.log and JobManager.log), however we are getting an error:
“Something went wrong, please check your link and try again.”
Could you please provide an alternate method to share the logs?
