Loss of Control Process CVJobRelicator.exe error in Auxilliary Copy
  • June 9, 2023
  • 7 replies
  • 617 views
Hi Guys,,,I am facing issues in multiple auxilliary copies. I am getting below error in the Aux copies every now and then.
Error Code: [19:599]
Description: Loss of control process CVJobReplicator.exe. Possible causes: 1. The control process has unexpectedly died. Check crash dump or core file. 2. The communication to the control process machine abc.com might have gone down due to network errors. 3. If the machine abc.com is a cluster, it may have failed over. 4. The machine abc.com may have rebooted. 5. Antivirus/Malware software may be blocking the process.
We are using Storeonce to replicate the primary snaps to the remote copy.
Kindly help here.
pank1988
Hi @pank1988 ,
What version are you using?
If too old, can you update and run a new Aux Copy.
Also, do you have any Process Dump?
If not can you configure the Media Agent to create one and log a case so we can check:
Best Regards,
Sebastien Merluzzi
  • June 12, 2023
We are using 11.28.63 version.
@pank1988 ,
Can you enable troubleshooting and log a case so we can check the dump?
Sebastien Merluzzi
Was a resolution found for this issue? I’m having a similar one.
Sherif
Rajiv
  • June 6, 2025
Hi ​@Sherif Guirguis
What version of CV you are on?
Best,
Rajiv Singal
  • August 6, 2025
we also had this problem today. im using 11.36
i did Resume and it disappeared, like it done or something.. any idea what does it mean?
Rajiv
  • August 6, 2025
@Ron Adar  It would be better to raise a support case to get this investigated.
Best,
Rajiv Singal
