LTO without label
  • April 25, 2023
  • 260 views
Forum|alt.badge.img+2
Hi Team,
I have tapes LTO7 without barcodes. Commvault can't identify them. How can I use them?
Best answer by Steve Scott
If your tape library doesn’t have a barcode reader, you can set it up as a Blind Library. The tapes get initialized with an On-Media Label (OML) by the system, which is a unique ID generated at the time of first ‘sight’ on the respective tapes.
Note that you may need to run a full discovery on the library, and if the library has already been configured with a barcode reader, you will need to obtain and apply LTO-7 labels to the tapes to make them usable.
If it’s a single tape drive, the configuration process is pretty similar.
Scott Moseman
Forum|alt.badge.img+23
I assume you need to purchase barcode labels for them?
Scott
I wanted to know if Commvault supports tapes without a barcode?
Scott Moseman
Probably not.  I’m sure barcodes are how we identify the tapes.
Scott
Steve Scott
  • April 25, 2023
