Currently we are running an M365 backup job using Azure Active directory and it is stuck at 84% since last 3 days. The status is showing as running. We are unable to figure out why its stuck here for so long?
Any thoughts?
Any thoughts?
Best answer by nishas
Apart from the raising a case could you check for archiveindex.logs it would also give an idea at what point it is stuck.
If possible can you paste logs here.
