Maintenance Mode / Activity Control
  • December 8, 2021
  • 868 views
Forum|alt.badge.img+13
we use Commvault Simpana 11.20.
Is there a posibility to set a matenance for the complete commcell or only for every media agent?
Regards
Dennis
Best answer by Stuart Painter
Hi @Dennis
Yes, you have the ability to control various activities at Commcell level.
Please take a look at List of CommCell Activities and CommCell Properties (Activity Control).
In the Java GUI you would right click on the Commcell Client item (top left in the tree) and then Activity Control tab to select and enable/disable activities.
You can choose to auto-re-enable activities after a certain delay to avoid forgetting to turn things back on - we have all had those days where something else takes over :grinning:
Stuart
Hi @Dennis
Stuart
