maximum jobs allowed synthetic full
  • October 16, 2023
  • 352 views
What are the coin and procs to enable JMSynthFullJobHighWaterMark. I know that standaard are 50 jobs  but we are using index V2 with more then 500 vm's. What are the recomended settings for synthetic full to not blast the MA.
We are currently running 4 Ma's
Best answer by Scott Moseman
I would suggest increasing in small increments and validating there are no negative impacts after each change. I imagine there is no “recommended” value since it is going to be dependent on the hardware and environment.
Scott
Hello @Egor Skepko
Synthetic Fulls are very I\O intensive for storage and could be resource intensive for MediaAgents.
As long as the storage, network, and MediaAgents can handle it, you can increase the number of Synth Fulls as much as you want.
Thank you,
Collin
Scott Moseman
Forum|alt.badge.img+23
  • October 16, 2023
Scott
  • October 17, 2023
@Scott Moseman @Collin Harper Ok thanks for the input, i will see how is going
