Answer
mongo db client removal
  • December 27, 2021
  • 127 views
Forum|alt.badge.img+9
We never backed up the client with MongoDB and want to remove it from the client and just leave the File System only.
Question, if I remove the MongoDB software, will it prompt me to uninstall the Media Agent, Storage Accelerator and IntelliSnap or do I have to remove them one by one ?
Current
my goal​​​​​
Best answer by Henry Zhan
Hi Gary,
I tested this in my lab sp24.7. It will not prompt for other components. Only Mongo component is removed.
Before removal:
After successful removal job
So please select all the components you want to remove when initiating the uninstall.
  • December 27, 2021
Hi Gary,
Before removal:
  • December 28, 2021
@Henry Zhan  , Would you try removing Media Agent, Storage Accelerator, IntelliSnap and see if it prompts you to restart the client ?
  • December 29, 2021
Hi Gary,
It will restart Commvault services but not restart the OS.
I verified removing MA and Intellisnap in lab. Storage Accelerator was not installed in my environment.
