mount path adding problem in storage policy copy
  • July 24, 2022
  • 347 views
hai guys,
please help to resolve the issue
when i try to add data path in data paths tab in storage policy copy it gives me this error below:
Best answer by Mike Struening
@AlphaFawad , it sounds like you want to move the copy to a new library, is that correct?  Do you want all of the existing jobs to move as well?
you can create a Synchronous Aux Copy to the new library, let it complete, then promote that new copy to the Primary.
Nice and clean.
Forum|alt.badge.img+18
  • July 24, 2022
Good afternoon.  Are you attempting to associate the new copy to a Storage Pool already used in this storage policy?  You can only use a storage pool once per storage policy.  If you have already used a storage pool in this storage policy, please select another and retry to add the copy.
  • July 24, 2022
no i want to assign another media agent with other storage library here to move backups to new library instaed of already added.
Nice and clean.
