MS SQL Client - what is the required steps to capturing a routine backup of the MS SQL msdb, master, and model dbs?
  • March 22, 2021
  • 155 views
not sure if I should create a new thread or not for my ms sql Bt..
for our MS SQL Client - what is the required steps to capturing a routine backup of the MS SQL msdb, master, and model dbs
@bc1410 , there’s a lot to unpack here (so definitely let me know if you have any specific questions!), so I’ll start with a high level overview.
This is our documentation for the CommCell console.
This is our documentation for command Center.
Once you have the subclient defined, you just need to schedule it out.  Command Center makes it really easy to set up a plan.
Take a look at those documents and let me know what questions arise.
  • March 22, 2021
Thanks Mike - Im going to take a look now at the links…  thank you… Will let you know..
Always!
