MS SQL IntelliSnap multi-instancing support
  • October 23, 2022
  • 129 views
Hi Experts,
our customer has a SQL Server with many SQL Instances.
The documentation mentions that multi instances are not supported.
https://documentation.commvault.com/11.26/expert/34617_intellisnap_faq_sql_server_agent.html
Can someone tell me the reason for this
Is it possible to backup one instance of SQL Server with IntelliSnap and the other instances via streaming backup?
Best regards,
Andreas
Best answer by Scott Reynolds
@ak2
When the Documentation states multi-instance it is referring to multiple instances of Commvault. This is a feature where you can have two separate CommVault installs on a single server sometimes pointing to two different commcells. More on that here:
https://documentation.commvault.com/11.26/expert/1841_multi_instance_installations.html
For the SQL agent you can have an unlimited number of SQL instances.
The reason for limiting CommVault instances is if you were to backup logs in both instances it would cause SQL chain breakage and cause various restore issues.
Yes you can have a SQL instance that leverages IntelliSnap and others that leverage streaming that is no problem.
@ak2
  • October 23, 2022
Hi Scott,
thanks for the quick reply!
That is then misleadingly described in the documentation.
best regards,
Andreas
