Multi Factor Authentication as SMS
  • July 19, 2022
  • 158 views
Hi Team,
can we use method SMS in MFA for the Web Console
Amr
Best answer by Jos Meijer
Only if you use a third-party solution such as SafeNet as an identity server. The internal solution only supports Email, Mobile Apps and Desktop Applications for pin.
Jos Meijer
Forum|alt.badge.img+21
  • Community All Star
  • July 19, 2022
  • August 18, 2022
Thanks Jos Meijer
