Multi instance on SQL cluster
  • June 25, 2024
  • 8 replies
  • 133 views
Can a second instance of commvault be installed on SQL cluster on windows?
Or are there any known issues with that?
Sunil
Forum|alt.badge.img+16
  • June 25, 2024
Hi @Sandy11
What is the use case for this? Why do we want to install different instances?
Sunil-
  • June 25, 2024
We are setting up a new commcell and existing commcell will be retained for legacy restores.
So need the client to have access to both.
Sunil
  • June 25, 2024
It is controlled by a key. Please raise a ticket with support. We can provide the key.
Sunil
Hi Sunil,
according to books online the Multiinstancing für SQL Server is not supported.
https://documentation.commvault.com/2023e/expert/multi_instance_support_01.html
But … there is a key to overcome this situation?
Regards.
Michael
Sunil
  • July 1, 2024
Yes, support can validate the use case carefully and can provide the override.
This is disabled specifically for SQL since running backups from both instances will result into data loss.
Sunil-
rolansaad
Apprentice
  • May 22, 2025
Hi ​@Sunil can you help to provide documentation that will support the override of SQL multi-instance support? We will do the same as well in our environment.
@rolansaad Please open a support case and we can assist.
rolansaad
Apprentice
  • May 22, 2025
Thanks a lot ​@Scott Reynolds.
