Multi-Person Authorization before Restore Operations
  • July 11, 2025
  • 100 views
Nikos.Kyrm
Forum|alt.badge.img+16
Hello Commvault community,
Our Security Department has requested information regarding the possibility of implementing a Multi-Person Authorization process before any download or restore operation of an Exchange Online mailbox.
Is there an option available for this kind of approval workflow, or any recommended approach?
(Reference: https://documentation.commvault.com/11.38/expert/authorization_operations_associated_with_get_and_process_authorization.html)
I would appreciate any feedback or experiences you can share.
Thank you in advance,
Nikos
Yes there is the restore authorization approval - its in the list on the page you pointed out. Its a workflow you download and implement from the store. I do not have experience with it myself but that should cover your restore need. I am unsure about download, however.
Nikos.Kyrm
  • Community All Star
  • July 14, 2025
Hello ​@Damian Andre Thanks for your reply.
Yes, I agree—there is a 'RestoreRequestAuthorization' workflow available. However, in our case, it might be tricky because it could keep requesting authentication, probably even for the end-user Self-Restore Portal!
So, I'm not sure if this workflow applies to the Self-Service Restore Portal as well. It might need to be tested.
Thanks again,
Nikos
