Need to change Encryption Algorithm from Blowfish to AES with 256 key on 600 clients by CLI command
  • January 28, 2023
  • 324 views
Dear Team,
Good Day!
I need to Encryption Algorithm from Blowfish to AES with 256 key on 600 clients, so is there any command line that I can execute to run on each storage policy, as changing through GUI, is time consuming.
Best answer by BackupOK
GOT IT THANKS
https://documentation.commvault.com/11.25/expert/7791_modifying_software_encryption_properties_of_storage_policy_copy_or_storage_pool_using_command_line_interface.html
close the thread.
  • January 28, 2023
Yes @BackupOK you are correct.
Note there is also a workflow for this function
https://cloud.commvault.com/webconsole/softwarestore/#!/136/671/13750
As well as a report that you are leverage that may be helpful
https://cloud.commvault.com/webconsole/softwarestore/#!/147/701/18096
