Need to rename Client Hostname in console in bulk, around 1500 clients
  • July 25, 2023
  • 155 views
Need to Rename Client Hostname in Commserve console in bulk, around 1500 clients
Rajiv
  • July 25, 2023
Hello @Yogesh Burud
You can refer the document: https://documentation.commvault.com/2022e/expert/4870_updating_client_properties_for_multiple_clients_using_command_line_interface.html
Please make extra caution while changing the names and since you are doing it for the first time, please perform it in a test environment.
You can also refer to the thread:
 Best,
Rajiv Singal
Forum|alt.badge.img+8
@Yogesh Burud
Please check this. You can change the client hostname from Commcell console or by using Command Line Interface locally.
On Commcell Console:
https://documentation.commvault.com/2022e/expert/7037_changing_host_name_of_client_computer.html
Using Command Line Interface
:https://documentation.commvault.com/2022e/expert/7051_changing_client_computer_name_using_command_line_interface.html
The command must be executed locally and cannot be used to change the name of a remote computer.
Note: Currently, there is no way to change the hostname in bulk. There are only 2 ways as mentioned above
@Yogesh Burud
Maximum you can try is keep the script with different value on a txt file and save that TXT as a .bat file.
Run the bat file so it will applicable for all.
