Netapp E2860 as SAN Backupstorage
  • February 17, 2023
  • 168 views
Hello
we are replacing our backup storage and have chosen a Netapp E2860. Is there any experience here in the community with this system or a few tips that we could still consider in the configuration? LUN size, block size other features ?
Kind Regards
Thomas
Best answer by lborek
Hi @lborek
What would be the optimal lun size for NTFS ? We have Windows as operating system on the media agents. For our old Backupstorage the Fujitsu DX100 we are using 9 TB Luns
As far i remember i copied options from here. You can find DDP pool specific configuration explained.
Pretty sure it would work on default settings too.
  • February 17, 2023
Please have a look at the vendor pdf, old but still valid.
https://www.netapp.com/pdf.html?item=/media/17042-tr4320pdf.pdf
They may have some additional info in their Support site Knowledge base.
  • Challenger
  • February 24, 2023
Hello @Ledoesp
thank you for the Document. The Document contains all the information that we need.
Kind Regards
Thomas
  • February 24, 2023
Hi Thomas,
We use couple of E2860 as disk library. Works really well.
60 drives pool from each shelf (3 spares reserved),  25TB luns and xfs on it :
parted -a optimal -s --  /dev/mapper/lib0-p5-v1 mklabel gpt mkpart primary xfs 0% 100%
mkfs.xfs -f -d su=131072,sw=8 -i size=1024 /dev/mapper/lib0-p4-v1-part1
  • Challenger
  • March 7, 2023
Hi @lborek
Onno van den Berg
Forum|alt.badge.img+24
Did you already buy the box(es)? Are you going to connect it to multiple MAs?
  • March 7, 2023
Hi @lborek
