Netapp hardware refresh
  • July 18, 2023
  • 86 views
Hello
I have in place many Intellisnap backups and every backup (Netapp snapshot) is replicated onto a secondary Netapp with Snapvault.
Now I must replace the current secondary Netapp with a new one maintaining all the current backups (snapshots) on the new secondary Netapp
What is the best approach ?
Regards
Federico
Best answer by Sebastien Merluzzi
Hi @Federico ,
The only way I can think of and unless someone has a better idea,  would be:
  • Add the new Array
  • Create a Third Copy using Second Copy as Source.
  • Aux Copy from Second to Third Copies.
  • Remove the Second Copy and change the Source of the Third Copy to use the First one.
Sebastien Merluzzi
Hi @Federico ,
  • Add the new Array
Sebastien Merluzzi
