Notification if Aux Copy job fails
  • March 25, 2023
  • 40 views
Forum|alt.badge.img+13
is it possible to get a notification if an AUX copy job fails? We had a problem with the tape library and we saw the problem a few days later.
Regards
Dennis
Best answer by dude
Here you go: https://documentation.commvault.com/2022e/expert/11511_auxiliary_copy_alerts.html
dude
Forum|alt.badge.img+20
  • Community All Star
  • March 26, 2023
Onno van den Berg
Forum|alt.badge.img+24
In case you are using Command Center than the amount of alerts you can select are very limited, so please use the CommCell console. I truly hope the amount of alerts that can be set from Command Center is expanded soon!
