Number of tapes.....
  • June 20, 2023
  • 118 views
Forum|alt.badge.img+13
is there a report where i can see how many tapes are needed within a week including compression?
We are considering using worms for archiving purposes and i would like to know how many tapes i need for that.
Regards
Dennis
Best answer by Matt Medvedeff
Hey Dennis,
You can run a Backup Job Summary report, on the Selection tab enable the option to show Associated Media:
Under Time Range tab, set for Last 7 days or specify the days of the week in question. This will generate a report of all the jobs that ran and the tapes they wrote to.
Hey Dennis,
