Oracle Automatic Schedule on FRA Percetage
  • May 17, 2023
  • 109 views
I’m trying to configure an automatic schedule for archive logs, We’ve configured the automatic schedule as the following screenshot:
We would like to know if that percetage is associated with the disk utilization and if its possible to configure with the FRA utilization, for example, when the FRA is 70% Full run an archive logs full backup.
We’ve testes and doesn’t seems to run the backup but a second opinion would be great.
Best regards and thanks in advanced.
Best answer by Emils
hi @Ilitia
Thanks for reaching out.
Current scheduled do not have a mechanism to monitor FRA, you can configure archive_log destination path to be set to the FRA and use the option “Start Backup when disk at log destination is” which would achieve the same outcome.
Emils
  • May 18, 2023
hi @Ilitia
  • May 18, 2023
Ok, Thank you much!!
