Hi all,
Currently user is running v11 SP25, Oracle backup was running fine until user upgraded Oracle firmware and hence the Full backup hit the abnormal behavior, failed and resumed and backup size will grow up to 33tb (actual DB size is 5tb)
I am not sure what is causing this issue, from logs I only manage to identified that connection was
15873 460e 02/19 13:15:23 1336308 CCvNetworkServer::ReadThread() - Could not peek for data format. Error:'0xFFFFFFFF:{CCvNetwork::PeekDataFormat(6495)} +
Just wondering if it was network issue it should not be able to run backup at all. I have attached some logs, appreciate if anyone could share some idea which part to check on. Thanks.
