Oracle Backups at Exadata Oracle Linux 7.8
  • May 18, 2021
  • 503 views
Hi all,
my commvault agent is not stable at Exadata with current OS-Release.
Did sb. experience problems post upgrading to current OS Release? Any workarounds known?
Best answer by Mike Struening
Sharing the solution here
Solution:
sUSECONNECTSTRING: https://documentation.commvault.com/commvault/v11/article?p=20970.htm
Important: Both the names and the categories (also called types) of additional settings are case sensitive. When you add or modify the name or the category of an additional setting, match the capitalization that is in the additional settings database.
  1. From the CommCell Browser, right-click the entity, and then click Properties.
  2. To work with a MediaAgent or a client, in the Properties dialog box, click Advanced.
  3. On the Additional Settings tab, click Add.
  4. In the Add Additional Settings dialog box, do the following:
  5. In the Name box, type the name of the additional setting.
  6. In the Category box, select the category for the additional setting, for example, CommServe.
  7. In the Type box, select the type for the additional setting, for example, Boolean.
  8. In the Value box, type the value of the additional setting.
  9. In the Comment box, enter comments for the additional setting.
  10. Click OK to save the additional setting configuration.
  11. To change the value of an existing additional setting, select the additional setting from the list, and then click Edit.
  12. Click OK.
Use the below document for reference to Data Guard Configuration to set the value : sORARUNBKPONDBROLE
https://documentation.commvault.com/commvault/v11/article?p=20991.htm
Tom Sheppard
Hi Ralf,
Can you provide some further details around the stability issue you are seeing?
For example, are you seeing process crashes? Or do jobs intermittently fail? If the latter, what errors are you seeing? etc
Thanks.
  • May 18, 2021
Hi @Tom Sheppard ,
at oracle db-server, in /var/log/…./cvd.log, I can see timeouts “Timed out while waiting for data in sockets” and much more ugly messages. Bouncing the commvault agent was a workaround which works for 1day+ but not for a week, means it is not a real workaround.
For sure it is easy to say “ check the network “ but ….
THX
Ralf
Tom Sheppard
Hi Ralf,
It would probably be easiest to troubleshoot this via a Support ticket.
If/when you raise that, please PM me the ticket ID for my reference.
Thanks.
  • May 24, 2021
Hi Tom,
I only can provide the CCID. 1009B0. In the meantime, commvault agent was patched again.
Cannot currently access to see if it is stable now.
Best regards,
Ralf
Solution:
  12. Click OK.
