Oracle home not correct after applying patch?
  • Aug 21, 2023 1:36 PM UTC
  • 294 views
Good morning,
We’re using rman/cron to back up our Oracle instances to commvault; we patched from 19.19 to 19.20 this weekend, and I noticed entries in events indicating a mismatch.  How can I resolve this?
Severity: Major
Program: CIDBControlAgent
Event code: 18:6
Description: Oracle home is not correct.
Best answer by Chris Newman
Closing the loop on this; Commvault backups succeed and it throws that event on the first backup attempt but does complete.  Afterwards, the databases reflect the new home and all good with zero intervention from us.
Forum|alt.badge.img+5
Hello @Chris Newman
Oracle home is not correct error seems that the destination instance is not configured properly.
The New Oracle home path can be taken from the DBA team. They need to update the Oracle Home directory by validating the same.
  • Aug 21, 2023 1:50 PM UTC
Thanks Tanuj, if we look at the database itself though (protect->databases), it does show the correct, new home.  Is this just a timing thing or?  A larger question is are we going to have this everytime we apply quarterly patches?  How to mitigate?
  • Aug 21, 2023 6:22 PM UTC
