Oracle Permissions
  • January 18, 2022
  • 721 views
Hi All,
an short question.
We have running an oracle instance on windows. The instance is running under user domain\x and the backup is running under domain\y user accounts.
In the reports we get the message:
Full access permissions not found for User [papstar\ora-home] on registry [SOFTWARE\CommVault Systems\Galaxy\Instance001]]. Please address these access rights.ll access permissions not found for User [domain\x] on registry [SOFTWARE\CommVault Systems\Galaxy\Instance001]]. Please address these access rights.
Is it correct that the user which runs the instance needs rights on this path ?
Best answer by Sunil
Sure. Here you go.
https://documentation.commvault.com/11.24/expert/20309_configuring_permissions_for_windows_oracle_home_user.html
Sunil-
Sunil
Forum|alt.badge.img+16
  • January 18, 2022
Hi @SSchmidt
That’s correct. The user which runs the Oracle instance needs rights on the Commvault paths. This is because during backup job, Oracle starts the backup processes as Oracle instance user.
Sunil-
  • Certified Expert
  • January 18, 2022
Hi @Sunil
thanks for your quick response. Do you know if there is any hint for this part in de cv docu ?
Sunil
  • January 18, 2022
Sunil
  • January 19, 2022
@SSchmidt Did you find what you’re looking for? Please let me know if you need any other detail.
Sunil-
