oracle rac - oci dbaas data guard - archive backp
  • November 6, 2025
  • 83 views
Forum|alt.badge.img+16
below is the current infra,
i need to use comvault to take db and archive logs , make sure logs are shipped and applied in oci instance
is it possible
| On-Prem RAC Cluster         |               | OCI Data Guard Standby DB    |
| (ASM Storage)               |   Redo Logs   | (Managed DBaaS, ASM)         |
| Node1 (Oracle Agent)        |               | (OCI Service Managed Apply)  |
| Node2 (Oracle Agent)        |               +------------------------------+
| Virtual Client (SCAN/VIP)   |
Forum|alt.badge.img+2
  • November 10, 2025
HI ​@Ajal@Ajal
Yes — it’s possible, but with a few key considerations.
Commvault can back up both the database and the archive logs from your on-prem Oracle RAC and keep the Data Guard standby in OCI synchronized, but it’s important to separate what Commvault handles vs. what Oracle Data Guard handles.
🔹 Commvault’s role:
Use the Oracle iDataAgent on each RAC node to back up the primary database and archive logs (from ASM).
Configure the backup type as ARCHIVE LOG + DATABASE with Data Guard awareness enabled.
You can schedule frequent archive log backups to ensure redo logs are captured and shipped out quickly.
🔹 Oracle Data Guard’s role:
The actual log shipping and apply between the on-prem RAC and OCI DBaaS standby are managed entirely by Oracle Data Guard, not Commvault.
Commvault does not push or apply redo logs to the standby — it just protects them.
🔹 Typical design:
1. Back up the primary RAC database and logs via Commvault.
2. Let Data Guard handle real-time redo transport and apply.
3. Optionally, protect the standby database as well for DR or compliance (Oracle Agent can run in backup-from-standby mode).
🔹 What’s supported:
Oracle RAC (ASM) on-prem as primary
OCI Data Guard standby (Managed DBaaS)
Backup of both sites with Oracle Agent
Commvault doesn’t control redo apply — that’s Oracle only
In short:
Use Commvault for backup and recovery, and Oracle Data Guard for log shipping and apply.
They complement each other — not replace one another.
  • November 12, 2025
​@Yann_ssg  thank you for the details , i would like to know how the logs are managed , once commvault take archive logs  , how it will make sure it is shipped before clearing the logs , or how the deleting logs work by making sure that it is applied
