Oracle RMAN command line backups not showing on commserve DB
  • July 20, 2023
  • 141 views
PedroRocha
Explorer
We are missing something. Running a simple full backup from RMAN command line, it kick a "(command line)" sublient job in the job controller. Ok so far…
But the job once it completes, I cannot see it from the commcell console job history. What else should be customized to have it correctly registered in the commserve DB?
Pedro
Hello Pedro,
Open the backup history from the instance level instead of subclient level.
Please check and confirm, are you able to see the command line jobs in the backup history tab?
Karthikeyan K
