Oralce custom script error
  • August 9, 2022
  • 65 views
i want to modify log
so, I went to customize script  in oracle.
but next error
What should i do?
Best answer by Sunil
Can you run Check readiness with Application readiness enabled?
Sunil-
Sunil
Forum|alt.badge.img+16
  • August 9, 2022
Hi @chris_ahn
Is the Oracle client reachable when you attempted this?
Sunil-
  • August 10, 2022
Thank you. Let me check
  • August 10, 2022
@Sunil I checked oracle status open.
Sunil
  • August 10, 2022
Sunil-
  • August 16, 2022
i will check tommrow
