Physical Pruning - Macro vs Micro pruning
  • April 26, 2023
  • 499 views
Hi, Unchecking the option Enable Physical Pruning will disable macro or micro pruning? Or both?
What is the difference between that option and the Enable pruning of aged data (Mount Path Property) below?
Best answer by Orazan
The top screenshot disables ALL pruning for the DDB you select this for.  The bottom screenshot disables ALL pruning for the mount path you select this for.
Forum|alt.badge.img+18
  • April 26, 2023
Zubair Ahmed Sharief
Hello @Eduardo Braga
Please see the below post for more information on macro pruning vs micro pruning
Micro vs Macro Pruning | Community (commvault.com)
