Port 27017
  • March 7, 2025
  • 53 views
Dear Vaulters,
I have a question, I have separated the webconsole from the CS to a dedicated machine, What would happen if the communication between CS and webconsole is not allowed over port 27017?
Forum|alt.badge.img+24
If there are any ports blocked between the wbeserver and command center (webconsole) machines, you must configure a network configuration to tell commvault to tunnel high ports.
https://documentation.commvault.com/2024e/expert/firewall_configurations_for_web_server_windows.html
You dont have to use a port forwarding gateway as suggested, even a direct network config can work - but if you don't do this then command center may not work with the mongodb port blocked.
