Port for Command Line (remote)
  • February 11, 2022
  • 386 views
Forum|alt.badge.img+8
Hi, I am wondering which port is needed to use the command line from a different machine than the CommServe. Is it for example the same port as for the CommCell Console, port 8401?
Best answer by Sarahy
Hello!
You would need to open port 8400 for communication.
https://documentation.commvault.com/11.24/essential/7102_port_requirements_for_commvault.html
Please let us know how it goes :)
Sarahy
Forum|alt.badge.img+5
  • February 11, 2022
Hello!
  • Certified Expert
  • February 16, 2022
I am currently working on the design for the environment which is pretty big. I'll know if it works in 3 months :-).
