PostgreSQL lack of space for WAL
  • Oct 27, 2026 10:07 AM UTC
  • 39 views
When running an Incremental database backup for PostgreSQL, Commvault waits for the archive_command to complete successfully. If the storage resource designated for archive WAL files is not large enough to hold all generated archive files, the backup process hangs/freezes while waiting for their archiving to finish.
Is it possible to configure Commvault so that it processes/backs up all currently available archived WAL files first and then waits for the remaining ones to be transferred?
Alternatively, does Commvault plan to introduce such a feature, or is this already on the product roadmap?
Lukasz
Meera
Forum|alt.badge.img+9
  • Oct 27, 2026 10:58 AM UTC
Hi Lukasz,
https://documentation.commvault.com/11.42/software/serverless_log_backups.html
serverless log backup feature provides capability to archive logs to MA library location. It avoids such delay in backup of logs and no space is required locally to archive logs.
https://documentation.commvault.com/11.42/software/optimizing_postgresql_log_backups.html#enable-serverless-log-backup
When this feature is enabled, archive_command is modified to copy the logs to library location in the MediaAgent associated with the instance. Whenever a log is ready to archive, it gets copied to the library location.
To append to the archive_command, instead of overwriting the existing command (for example: incase of replication setup), set the bPreserveArchiveCommandWithDumpSweep additional setting under PostGres to 1.
Meera
  • Oct 28, 2026 10:19 AM UTC
I've already informed the customer about serverless log backup, but they claim it’s not a suitable solution for them.
They need confirmation on whether there are any other options available for this use case.
In the meantime, the customer found a workaround using wal_compression, but it isn't mentioned in the Commvault documentation. Could you please confirm if this is supported by Commvault?
Łukasz
Meera
  • Oct 28, 2026 10:37 AM UTC
Hi Lukasz,
Please see this - https://documentation.commvault.com/2024e/commcell-console/faq_05.html#do-we-support-compression-for-transaction-logs
Just curious—is there a particular reason why serverless log backups is not suitable for them?
Meera
  • Nov 3, 2026 1:25 PM UTC
about serverless:
“During a restore operation, WAL restores all required WAL files to the location specified in archive_command. Therefore, we would still need to provision space to restore these files. Currently, this location is on a separate filesystem.”
We wanted to use PostgreSQL's built-in mechanism—the wal_compression parameter set to lz4. In that case, there is no need to modify restore_command. I assume this does not affect Commvault, as it does not fundamentally change the archived file itself. Since it works with gzip, it should definitely work with the built-in mechanism. However, please confirm this. We couldn't find any such information in the documentation.
Lukasz
  • Nov 3, 2026 1:43 PM UTC
also they wanted confirmation that there is no such option like partial backup of WAL files.
Lukasz
