Pro / Contra Enryption
  • May 21, 2026
  • 52 views
Forum|alt.badge.img+13
actually we do not encrypt our backups.
Make it sense to encrypt them?
Thanks and Regards
Dennis
Best answer by Paul G
Hi ​@Dennis,
This has a simple answer:
YES!
More detailed: Why would you not encrypt your backups? Encryption does cause a (very) small hit to performance and load but you are much better off to have it when you have a security breach.
With more regulations nowadays by a lot of governments (EU mindset in this case), it is probably mandatory for a lot of companies to ensure protection of their data now or in the future.
Kind regards,
Paul Germanus
Paul G
Explorer
Forum|alt.badge.img+2
  • May 21, 2026
Hi ​@Dennis,
YES!
Kind regards,
Paul Germanus
Scott Moseman
Forum|alt.badge.img+23
Enable encryption.  No question.
Scott
