Problem with instalation File System Core
  • February 9, 2023
  • 891 views
hello colleagues,
Please help with one problem when installing commvault. it can't install File System Core. I tried to reinstall and uninstall completely everything about commvault in program files and programmdata. Thank you
Log
11504 1     02/09 16:07:58 ### ### ### - Installing packages...
11504 1     02/09 16:08:05 ### ### ### - Checking and removing stale MSI with product [File System Core]
11504 1     02/09 16:08:06 ### ### ### - Started install/update of package: WindowsFileSystemiDataAgentCore...
11504 1     02/09 16:08:06 ### ### ### - Error: Не удалось установить File System Core(WindowsFileSystemiDataAgentCore) с кодом ошибки 0x80070643.
11504 1     02/09 16:08:06 ### ### ### - Set application exit code=[Failed]
11504 1     02/09 16:08:06 ### ### ### - Apply packages completed ...  Status = -2147023293
11504 1     02/09 16:08:06 ### ### ### - Error: Installation failed. Please check the logs at [C:\Program Files\Commvault\ContentStore\Log Files].
11504 1     02/09 16:08:06 ### ### ### - Set application exit code=[FailedInstallPackage]
11504 4     02/09 16:08:06 ### ### ### - Showing dialog : CompletionExitViewModel .......
Best answer by Jos Meijer
Your log shows:
Translated: Installation failed with error code 0x80070643.
Error code 0x80070643 possibly refers to your Dot Net installation on the server, eithe not existing or corrupt. As Commvault used Dot Net this could indeed be the reason for the installation to fail.
There are a few things to check.
Please keep in mind that the Dot Net requirements are different per Commvault version so my screenshots can look different:
  • Check if Dot Net is installed via “Add roles and features”:
  • Try installing the 3rd party Dot Net packages manually from the Software Installation folder. Location “<software install files folder>\ThirdParty” :
Jos Meijer
Forum|alt.badge.img+21
  • Community All Star
  • February 9, 2023
Can you run a repair of your . net installation and try again?
  • February 10, 2023
hellowhat do you mean? i don't understand
Hi @Ruslan ,
You can uninstall and reinstall. Net from Third Party.
Sebastien
Jos Meijer
  • February 10, 2023
Your log shows:
Hi @Ruslan ,
Don’t hesitate to log a case with us, we will check and resolve the issue for you.
Sebastien
  • February 28, 2023
I am sorry for long answer. User was busy
i tried reinstalling the whole folder ThirdParty.
DotNetFramework is not installed, says a newer version is installed.
