Problem with NDMP backup Error Code: [39:44]
  • Jul 26, 2023 11:51 AM UTC
  • 107 views
Hello all!
We do have NDMP backup configured within our environment.
The parent path looks like that:
/stpbdedcfs101/f3_cifs_dfs_shares09/dfsshares09
there was a first fail while creating full backup with this kind of error:
now every next incremental backup does fails with this kind of error:
This whole location is still in use and accessible. We have confirmed that while “browsing for new content”
While checking logs i have discovered following message:
As you can see at the previous screenshot location DFS_000651_HG_DEMU_VK exist.
Is that error men that backup is not able to access this particular location?
As You can see backup fails with only 1 “Failed folder”
So does that means, that this incremental backup is not seeing any changes within the whole parent location and fails only because it is not able to access DFS_000651_HG_DEMU_VK ?
Best answer by Arunkumar P
@Grzegorz - Looks like a bug to me. Can you please log a case with us to investigate further on this issue?
Make sure to upload the logs and screenshot of the volume name that needs to be captured at the storage end.
Arunkumar P
Forum|alt.badge.img+9
  • Jul 27, 2023 6:06 AM UTC
