Problem with VM Live Sync replication
  • August 24, 2022
  • 13 replies
  • 2264 views
I have the following error messages in the log
7244  f68   08/24 12:54:51 173589 [msg.dictionary.load.openFailed] Cannot open file "C:\ProgramData\VMware\VMware Virtual Disk Development Kit\config.ini": The system cannot find the file specified.
7244  f68   08/24 12:54:51 173589 lib/ssl: protocol list tls1.2 (openssl flags 0x17000000)
7244  f68   08/24 12:54:51 173589 lib/ssl: cipher list ECDHE+AESGCM:RSA+AESGCM:ECDHE+AES:RSA+AES
7244  f68   08/24 12:54:51 173589 lib/ssl: curves list prime256v1:secp384r1:secp521r1
7244  f68   08/24 12:54:51 173589 FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:\ProgramData\VMware): Cannot create a file when that file already exists (183)
Best answer by Jos Meijer
Today I had time again to check the media agent install.
Issue definitely was in the Client object for this Media Agent.
Reinstalled Media Agent with new Client object, reconfigured DDB, Disklibrary, Tape Library and VSA relations for VM Live Sync.
Commserve also had issues, all sockets were in use.
Removed non-needed TPPM configurations and DIP's, rebooted Commserve.
Socket issue is gone, normal amount of sockets in use.
Tested DDB backup, Aux to disk and tape, VM replication, all works for this media agent.
Juan Pablo and I agree that this call can be closed @Mike Struening 👍
Jos Meijer
Forum|alt.badge.img+21
  • Community All Star
  • August 24, 2022
These seem to be default "error" messages which are generated by the vddk. Which are common vsa log entries. Not expecting these messages to cause an error in a VM live sync process.
Can you describe the issue your experiencing with VM live sync?
  • August 25, 2022
I am experiencing problems when it starts to restore the VMs, sending the following:
File : vsrst.log
8684 2550 08/25 14:12:05 173736 = VSRST has started vsrst -j 173736 -cn commvault-drp -vm Instance001
8684 2550 08/25 14:12:05 173736 ================================================================
8684 2550 08/25 14:12:05 173736 CVMDiskInfo::GetVDDKInstallPath() - Using vStorage VDDK from [C:\Program Files\Commvault\ContentStore\Base\VMware\VDDK\VDDK673] version [6.7.3 build-14389676]
8684 2550 08/25 14:12:05 173736 CVMDiskInfo::LoadVDDKLibrary() - Successfully loaded VDDK Lib (libeay32.dll) from C:\Program Files\Commvault\ContentStore\Base\VMware\VDDK\VDDK673\bin\libeay32.dll
8684 2550 08/25 14:12:05 173736 CVMDiskInfo::LoadVDDKLibrary() - Successfully loaded VDDK Lib (ssleay32.dll) from C:\Program Files\Commvault\ContentStore\Base\VMware\VDDK\VDDK673\bin\ssleay32.dll
8684 2550 08/25 14:12:05 173736 CVMDiskInfo::LoadVDDKLibrary() - Successfully loaded VDDK Lib (libldap_r.dll) from C:\Program Files\Commvault\ContentStore\Base\VMware\VDDK\VDDK673\bin\libldap_r.dll
8684 2550 08/25 14:12:05 173736 CVMDiskInfo::LoadVDDKLibrary() - Successfully loaded VDDK Lib (libcurl.dll) from C:\Program Files\Commvault\ContentStore\Base\VMware\VDDK\VDDK673\bin\libcurl.dll
8684 2550 08/25 14:12:05 173736 VSRstApp::Initialize() - Initializing Job manager object
8684 1780 08/25 14:12:05 173736 CVDTerminationHandler::_WaitForCVDTermination() - Waiting for CVD Termination
8684 2550 08/25 14:12:06 173736 Cvcl::init() - CVCL: Running in FIPS Mode
8684 2550 08/25 14:12:06 173736 vsJobMgr::LoadJobOptions() - Job Options: <?xml version='1.0' encoding='utf-8' ?><TMMsg_JobOption><backupOpts backupLevel="2"><dataOpt autoCopy="0"/></backupOpts><adminOpts><contentIndexingOption subClientBasedAnalytics="0"/></adminOpts><restoreOptions><virtualServerRstOption isVolumeBrowse="0" isVirtualLab="0" esxServer="" isAttachToNewVM="0" isBlockLevelReplication="0" isDiskBrowse="1" viewType="0" replicationGuid="d5734afd-21a6-481c-b008-14ec429ec141" isFileBrowse="0"><vCenterInstance clientId="287" clientName="VCSADRP" instanceName="VMware" appName="Virtual Server" instanceId="20" applicationId="106"/><diskLevelVMRestoreOption passUnconditionalOverride="0" vcloudHostName="" hostOrCluster="" useVcloudCredentials="0" diskOption="2" powerOnVmAfterRestore="0" esxServerName="vcsadrp.da.shf.gob.mx" transportMode="0" maxNumOfVMPerJob="0"><userPassword userName="commvaultdrp@vsphere.local"/><advancedRestoreOptions esxHost="vmw-esx-drp-03.da.shf.gob.mx" resourcePoolPath="/" destComputerName="" FolderPath="/DC-DRP/vm/DRP_SHF/Replicas" newName="VM10-SAGAPL-DRP" Datastore="TrueNAS03" name="VM10-SAGAPL" guid="50102547-15b7-de98-7241-87a67323f581"><disks Datastore="TrueNAS03" name="scsi0-0-VM10-SAGAPL.vmdk"/><disks Datastore="TrueNAS03" name="scsi0-1-VM10-SAGAPL_1.vmdk"/><nics subnetId="" sourceNetwork="DSPGV82usr_82 (DSVMS)" sourceNetworkId="dvportgroup-1635" networkName="" destinationNetwork="VLAN708"/><vmIPAddressOptions destinationIP="10.10.82.45" destinationSubnet="255.255.255.128" alternateDNS="192.168.105.183" primaryWins="" alternateWins="" sourceSubnet="255.255.255.128" sourceIP="10.10.82.45" sourceGateway="10.10.82.126" primaryDNS="192.168.105.245" destinationGateway="10.10.82.126" useDhcp="0"/></advancedRestoreOptions><defaultRestoreSettings cluster="" esxHost="" protectionGroup="" resourcePoolPath="" datacenter="" DestinationPath="" Datastore=""/></diskLevelVMRestoreOption><allocationPolicy vmAllocPolicyId="0"/></virtualServerRstOption><volumeRstOption volumeLeveRestore="0" volumeLevelRestoreType="1" destinationVendor="1"/><browseOption listMedia="0" useExactIndex="0" noImage="0" commCellId="2" showDeletedItems="1"><mediaOption useISCSIMount="0"><mediaAgent mediaAgentId="0" _type_="11"/><library _type_="9" libraryId="0"/><copyPrecedence copyPrecedence="0" copyPrecedenceApplicable="0"/><drivePool _type_="47" drivePoolId="0"/></mediaOption><backupset instanceName="VMware" backupsetId="99" clientId="217" applicationId="106"/><timeZone _type_="55" TimeZoneID="24" TimeZoneName="(UTC-06:00) Guadalajara, Mexico City, Monterrey"/><timeRange/></browseOption><commonOptions systemStateBackup="0" clusterDBBackedup="0" powerRestore="0" restoreToDisk="0" copyToObjectStore="0" onePassRestore="0" syncRestore="0" detectRegularExpression="1" wildCard="0"/><destination inPlace="0"><destClient clientId="40"/></destination><fileOption><sourceItem val="\50102547-15b7-de98-7241-87a67323f581"/><browseFilters val="&lt;?xml version='1.0' encoding='UTF-8'?&gt;&lt;databrowse_Query type=&quot;0&quot; queryId=&quot;0&quot; /&gt;"/><browseFilters val="&lt;?xml version='1.0' encoding='UTF-8'?&gt;&lt;databrowse_Query type=&quot;0&quot; queryId=&quot;0&quot; /&gt;"/><browseFilters val="&lt;?xml version='1.0' encoding='UTF-8'?&gt;&lt;databrowse_Query type=&quot;0&quot; queryId=&quot;0&quot; /&gt;"/></fileOption></restoreOptions><commonOpts><automaticSchedulePattern useStorageSpaceFromMA="0"/></commonOpts><vmBrowsePathNodes esxHost="vmw-esx-drp-03.da.shf.gob.mx" datastore="TrueNAS03" vcloudVappName="" vmEsxHost="vmw-esx-drp-03.da.shf.gob.mx" vmInventoryPath="/DC-DRP/vm/DRP_SHF/Replicas" vmDataStore="TrueNAS03" isMetadataAvaiable="1" folder="" vcloudOrgVdcName="" vcloudOwner="" vmeResourcePoolPath="/" resourcePoolPath="/" DisplayName="VM10-SAGAPL" diskType="0" vcloudOrgName="" vmGUID="50102547-15b7-de98-7241-87a67323f581" browsePath="VM10-SAGAPL" isDriveNode="1"><nics subnetId="" sourceNetwork="DSPGV82usr_82 (DSVMS)" sourceNetworkId="dvportgroup-1635" networkName="" destinationNetwork="VLAN708"/></vmBrowsePathNodes><vmBrowsePathNodes esxHost="" datastore="" vcloudVappName="" vmEsxHost="" vmInventoryPath="" vmDataStore="" isMetadataAvaiable="1" folder="" vcloudOrgVdcName="" vcloudOwner="" vmeResourcePoolPath="" resourcePoolPath="" DisplayName="catalog" diskType="0" vcloudOrgName="" vmGUID="50102547-15b7-de98-7241-87a67323f581" browsePath="VM10-SAGAPL\catalog" isDriveNode="0"/><vmBrowsePathNodes esxHost="" datastore="" vcloudVappName="" vmEsxHost="" vmInventoryPath="" vmDataStore="" isMetadataAvaiable="1" folder="" vcloudOrgVdcName="" vcloudOwner="" vmeResourcePoolPath="" resourcePoolPath="" DisplayName="VM10-SAGAPL.nvram" diskType="0" vcloudOrgName="" vmGUID="50102547-15b7-de98-7241-87a67323f581" browsePath="VM10-SAGAPL\VM10-SAGAPL.nvram" isDriveNode="0"/><vmBrowsePathNodes esxHost="" datastore="TrueNAS03" vcloudVappName="" vmEsxHost="" vmInventoryPath="" vmDataStore="TrueNAS03" isMetadataAvaiable="1" folder="" vcloudOrgVdcName="" vcloudOwner="" vmeResourcePoolPath="" resourcePoolPath="" DisplayName="VM10-SAGAPL.vmdk" diskType="18" vcloudOrgName="" vmGUID="50102547-15b7-de98-7241-87a67323f581" browsePath="VM10-SAGAPL\scsi0-0-VM10-SAGAPL.vmdk" isDriveNode="0"/><vmBrowsePathNodes esxHost="" datastore="" vcloudVappName="" vmEsxHost="" vmInventoryPath="" vmDataStore="" isMetadataAvaiable="1" folder="" vcloudOrgVdcName="" vcloudOwner="" vmeResourcePoolPath="" resourcePoolPath="" DisplayName="VM10-SAGAPL.vmx" diskType="0" vcloudOrgName="" vmGUID="50102547-15b7-de98-7241-87a67323f581" browsePath="VM10-SAGAPL\VM10-SAGAPL.vmx" isDriveNode="0"/><vmBrowsePathNodes esxHost="" datastore="" vcloudVappName="" vmEsxHost="" vmInventoryPath="" vmDataStore="" isMetadataAvaiable="1" folder="" vcloudOrgVdcName="" vcloudOwner="" vmeResourcePoolPath="" resourcePoolPath="" DisplayName="VM10-SAGAPL.vmxf" diskType="0" vcloudOrgName="" vmGUID="50102547-15b7-de98-7241-87a67323f581" browsePath="VM10-SAGAPL\VM10-SAGAPL.vmxf" isDriveNode="0"/><vmBrowsePathNodes esxHost="" datastore="TrueNAS03" vcloudVappName="" vmEsxHost="" vmInventoryPath="" vmDataStore="TrueNAS03" isMetadataAvaiable="1" folder="" vcloudOrgVdcName="" vcloudOwner="" vmeResourcePoolPath="" resourcePoolPath="" DisplayName="VM10-SAGAPL_1.vmdk" diskType="18" vcloudOrgName="" vmGUID="50102547-15b7-de98-7241-87a67323f581" browsePath="VM10-SAGAPL\scsi0-1-VM10-SAGAPL_1.vmdk" isDriveNode="0"/><vmBrowsePathNodes esxHost="" datastore="" vcloudVappName="" vmEsxHost="" vmInventoryPath="" vmDataStore="" isMetadataAvaiable="1" folder="" vcloudOrgVdcName="" vcloudOwner="" vmeResourcePoolPath="" resourcePoolPath="" DisplayName="vmware-1.log" diskType="0" vcloudOrgName="" vmGUID="50102547-15b7-de98-7241-87a67323f581" browsePath="VM10-SAGAPL\vmware-1.log" isDriveNode="0"/><vmBrowsePathNodes esxHost="" datastore="" vcloudVappName="" vmEsxHost="" vmInventoryPath="" vmDataStore="" isMetadataAvaiable="1" folder="" vcloudOrgVdcName="" vcloudOwner="" vmeResourcePoolPath="" resourcePoolPath="" DisplayName="vmware-2.log" diskType="0" vcloudOrgName="" vmGUID="50102547-15b7-de98-7241-87a67323f581" browsePath="VM10-SAGAPL\vmware-2.log" isDriveNode="0"/><vmBrowsePathNodes esxHost="" datastore="" vcloudVappName="" vmEsxHost="" vmInventoryPath="" vmDataStore="" isMetadataAvaiable="1" folder="" vcloudOrgVdcName="" vcloudOwner="" vmeResourcePoolPath="" resourcePoolPath="" DisplayName="vmware-3.log" diskType="0" vcloudOrgName="" vmGUID="50102547-15b7-de98-7241-87a67323f581" browsePath="VM10-SAGAPL\vmware-3.log" isDriveNode="0"/><vmBrowsePathNodes esxHost="" datastore="" vcloudVappName="" vmEsxHost="" vmInventoryPath="" vmDataStore="" isMetadataAvaiable="1" folder="" vcloudOrgVdcName="" vcloudOwner="" vmeResourcePoolPath="" resourcePoolPath="" DisplayName="vmware.log" diskType="0" vcloudOrgName="" vmGUID="50102547-15b7-de98-7241-87a67323f581" browsePath="VM10-SAGAPL\vmware.log" isDriveNode="0"/></TMMsg_JobOption>
8684 2550 08/25 14:12:06 173736 Init() - Initializing job control [token=,cn=commvault-drp], serverName [commvault-drp.da.shf.gob.mx], ControlFlag [1], Job Id [173736]
8684 2550 08/25 14:12:06 173736 JM Client () - Failed to attach to remote service on retry 1. We will try again after some time
8684 2550 08/25 14:12:36 173736 CVJobCtrlClient::startSession()() - Failed to start a session with CVD. SessionError[150995030]::Error String[Internal Error [150994957] in CVSession while communicating with remote host [Remote system []. Required parameter missing [Remote client name].]. []], timedOut[FALSE]
8684 2550 08/25 14:12:36 173736 Init() - Error registering JOB with the Communications Service for JobID [173736]
8684 2550 08/25 14:12:36 173736 SetupConnectionWithCVD() - SetupConnectionWithCVD failed. mangledHostName= localClientName=commvault-drp TimeOut=False, error=0x80070057:{CCvNetwork::Attach_RemoteService(1692)} + {CCvNetwork::Attach_RemoteService(1655)} + {CCvNetwork::LookupRegisteredPorts(4700)} + {CCvNetwork::LookupRegisteredPorts_Common(4773)} + {CCvNetwork::DemangleHostNameToComps(4846)/W32.87.(The parameter is incorrect. (ERROR_INVALID_PARAMETER.87))-Invalid mangled host name:[] passed. Please use mangled host name.}
8684 2550 08/25 14:12:36 173736 SendToCVD() - Couldn't setup the connection
8684 2550 08/25 14:12:36 173736 Init() - registerJob failed. Returning failure
8684 2550 08/25 14:12:36 173736 vsJobMgr::init() - Failed to initialize job controller. CSName[ commvault-drp.da.shf.gob.mx], jobId [173736], JobMgrToken []
8684 2550 08/25 14:12:36 173736 VSRstApp::Initialize() - Job manager initialization failed
8684 1780 08/25 14:12:36 173736 CVDTerminationHandler::_WaitForCVDAliveMutex() - CVD Alive Check Quit Event Signaled
8684 2550 08/25 14:12:36 173736 = VSRst has exited
8684 2550 08/25 14:12:36 173736 ================================================================
8684 1fec 08/25 14:12:36 173736 JM Client () - Failed to attach to remote service on retry 1. We will try again after some time
8684 1fec 08/25 14:13:06 173736 CVJobCtrlClient::startSession()() - Failed to start a session with CVD. SessionError[150995030]::Error String[Internal Error [150994957] in CVSession while communicating with remote host [Remote system []. Required parameter missing [Remote client name].]. []], timedOut[FALSE]
8684 1fec 08/25 14:13:06 173736 controlThread() - Failed to unregister job with the Communications Service for JobID [173736]
Jos Meijer
  • August 25, 2022
Here lies your issue:
Have seen this multiple times on different versions, need to look back what the solution was. Not sure if this was DNS resolving or a Commvault internal issue.
Which Commvault version are you using?
Is this a newly installed VSA?
Can you share CVD.log? Curious if you have an anti chatter log entry.
Jos Meijer
  • August 25, 2022
How is this VSA installation performed? Manually? If so did you use an XML file for the parameters? If not manually, via Push install or automation?
Reason for asking is, after reviewing support calls and taking another look at the log section, there is no mangled hostname provided. This could indicate that there was invalid information provided during the installation or a problem with the Commvault installation on this server.
A manual workaround in some old support cases was to manually edit registry by changing AntiChatterFlag to 0 and edit CsClientName with shortname and cycling the Commvault services on the client.
Some support cases also show a hotfix dependency, curious which Commvault version you are using.
  • August 25, 2022
It is a media Agent already in use, it has been working for several years, it was recently updated to SP24.60, but before the update it already had the problem.I share the log.
6280  74c   08/25 15:46:36 ###### TPool [SdtHeadThPool]. Tot [0], Pend [0], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
6280  dd0   08/25 15:46:37 ------ CCVDSpaceCheck::CleanupIdleEventConnections() - Invoking CleanUp Idle Event Connections.
6280  f24   08/25 15:46:37 ###### GetRootFolders() - AllUsersProfileDirectory - [C:\ProgramData]
6280  72c   08/25 15:46:37 ###### IndexCacheCleanUpV2: Starting index cache cleanup thread
6280  72c   08/25 15:46:37 ###### getMyHostName_SpaceCheck() - ERROR: cannot determine mangled hostname for 'commvault-drp'
6280  72c   08/25 15:46:37 ###### IndexCacheCleanUpV2: failed to submit task. err [0xECCC0016:{CVOnDemandSvcClient::SubmitTask(43)/ErrNo.22.(Invalid argument)-mangled hostname and/or application name is empty}]
6280  72c   08/25 15:46:37 ------ launchCleanupService() - Failed to attach to CVD(IDXMessageHandler) on []
6280  72c   08/25 15:46:37 ------ IndexCacheMaintenance() - Regular cleanup skipped or failed: 0x80070057:{CCvNetwork::Attach_RemoteDLL(1419)} + {CCvNetwork::DemangleHostNameToComps(4846)/W32.87.(The parameter is incorrect. (ERROR_INVALID_PARAMETER.87))-Invalid mangled host name:[] passed. Please use mangled host name.}
6280  72c   08/25 15:46:37 ------ IndexCacheMaintenance() - Index cache for client [commvault-drp] is using 126786 MB. Location is [F:\Index].
6280  f58   08/25 15:46:38 ###### CCVIOMonitorLib::MonitorThreadStatic(568) - Total time spent in Anomaly detection: 0.001963
6280  f58   08/25 15:46:38 ###### CCVIOMonitorLib::MonitorThreadStatic(569) - Time spent in Anomaly detection algorithm: 0.000000
6280  584   08/25 15:46:55 173730 2-# [FSRESTHEAD ] Stats: AppTy 106, AF 2, Seeks 0/2/6, WrkItms 7, MsgsRcvd 21, QLen 13, LstMsg CLOSE_ARCHIVE_AND_REL_VOL
6280  584   08/25 15:46:55 173730 2-# [FSRESTHEAD ] Stats: [AllocBuf Time] Exp Avg [0.00], Total Avg [0.00], Total Time [0.00], Total Count [52]
6280  584   08/25 15:46:55 173730 2-# [FSRESTHEAD ] Stats: [AllocBuf Speed] Curr Avg [24399.13] MB/Sec, Bytes [3405792]; Total Avg [24399.13] MB/Sec, Bytes [3405792]
6280  584   08/25 15:46:55 173730 2-# [FSRESTHEAD ] Stats: [MediaRead Time] Exp Avg [0.00], Total Avg [0.00], Total Time [0.00], Total Count [52]
6280  584   08/25 15:46:55 173730 2-# [FSRESTHEAD ] Stats: [MediaRead Speed] Curr Avg [189.47] MB/Sec, Bytes [612909]; Total Avg [189.47] MB/Sec, Bytes [612909]
6280  584   08/25 15:46:55 ###### [FSRESTHEAD ] CSSrv::ChkState: Clnt [commvault-shf], JobId [0], Rdr has not progressed.
6280  21a8  08/25 15:46:57 ###### CFolderIOInfoWriter::PruneRecordsOlderThan(161) - Pruning successful, ClientId=[40], PruneTime=[2022/07/26 20:46:57.139327Z (1658868417)]
6280  21a8  08/25 15:46:57 ###### CFolderLevelIOInfoWriter::PruneRecordsOlderThan(681) - Pruning successful, ClientId=[40], PruneTime=[2022/08/18 20:46:57.139327Z (1660855617)]
6280  18e4  08/25 15:48:14 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 15:48:14 173730 1-# [DM_BASE    ] Setting the job state to running
6280  18e4  08/25 15:48:14 173730 1-# [DM_BASE    ] Going to retry the Restore Mount.
6280  18e4  08/25 15:48:16 173730 1-# [DM_BASE    ] **ERROR** reserveMountVol Failed VolumeId = 29833 MA hostName- commvault-drp.da.shf.gob.mxClientName - commvault-drp MediaManager returned error [803], errorString [The medium is already reserved by some other job[s].]
6280  18e4  08/25 15:48:16 173730 1-# [DM_BASE    ] Going to check whether the mount should be retried for the above mediamanager error
6280  18e4  08/25 15:48:16 173730 1-# [DM_BASE    ] The mount will be retried for the MediaManager error [803] after sleeping for [120] seconds.
6280  18e4  08/25 15:48:16 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 15:48:16 173730 1-# [DM_BASE    ] Setting the job state to waiting
6280  18e4  08/25 15:50:16 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 15:50:16 173730 1-# [DM_BASE    ] Setting the job state to running
6280  18e4  08/25 15:50:16 173730 1-# [DM_BASE    ] Going to retry the Restore Mount.
6280  18e4  08/25 15:50:18 173730 1-# [DM_BASE    ] **ERROR** reserveMountVol Failed VolumeId = 29833 MA hostName- commvault-drp.da.shf.gob.mxClientName - commvault-drp MediaManager returned error [803], errorString [The medium is already reserved by some other job[s].]
6280  18e4  08/25 15:50:18 173730 1-# [DM_BASE    ] Going to check whether the mount should be retried for the above mediamanager error
6280  18e4  08/25 15:50:18 173730 1-# [DM_BASE    ] The mount will be retried for the MediaManager error [803] after sleeping for [120] seconds.
6280  18e4  08/25 15:50:18 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 15:50:18 173730 1-# [DM_BASE    ] Setting the job state to waiting
6280  74c   08/25 15:51:36 ###### TPool [CVDMessageHandler]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [327.21 us], Avg Wait Time [101.93 us]
6280  74c   08/25 15:51:36 ###### TPool [CVDMessageHandler]. Ser# [1] Tot [7], Pend [1], Comp [6], Max Par [4], Avg Work Time [199.79 ms], Avg Wait Time [1.54 ms]
6280  74c   08/25 15:51:36 ###### TPool [IOCPServerPool_JobControlCVD]. Ser# [1] Tot [28], Pend [28], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
6280  74c   08/25 15:51:36 ###### TPool [IOCPServerPool_CVD]. Ser# [1] Tot [28], Pend [28], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
6280  74c   08/25 15:51:36 ###### TPool [CVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [31.19 us], Avg Wait Time [85.64 us]
6280  74c   08/25 15:51:36 ###### TPool [CVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [256.47 us], Avg Wait Time [50.27 us]
6280  74c   08/25 15:51:36 ###### TPool [IOCPServerPool_SysMonEventSink]. Ser# [1] Tot [28], Pend [28], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
6280  74c   08/25 15:51:36 ###### TPool [SdtHeadThPool]. Tot [0], Pend [0], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
6280  72c   08/25 15:51:37 ###### GetRootFolders() - AllUsersProfileDirectory - [C:\ProgramData]
6280  f58   08/25 15:51:38 ###### CCVIOMonitorLib::MonitorThreadStatic(568) - Total time spent in Anomaly detection: 0.002399
6280  f58   08/25 15:51:38 ###### CCVIOMonitorLib::MonitorThreadStatic(569) - Time spent in Anomaly detection algorithm: 0.000000
6280  21a8  08/25 15:51:57 ###### CFolderIOInfoWriter::PruneRecordsOlderThan(161) - Pruning successful, ClientId=[40], PruneTime=[2022/07/26 20:51:57.254812Z (1658868717)]
6280  21a8  08/25 15:51:57 ###### CFolderLevelIOInfoWriter::PruneRecordsOlderThan(681) - Pruning successful, ClientId=[40], PruneTime=[2022/08/18 20:51:57.254812Z (1660855917)]
6280  18e4  08/25 15:52:18 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 15:52:18 173730 1-# [DM_BASE    ] Setting the job state to running
6280  18e4  08/25 15:52:18 173730 1-# [DM_BASE    ] Going to retry the Restore Mount.
6280  18e4  08/25 15:52:20 173730 1-# [DM_BASE    ] **ERROR** reserveMountVol Failed VolumeId = 29833 MA hostName- commvault-drp.da.shf.gob.mxClientName - commvault-drp MediaManager returned error [803], errorString [The medium is already reserved by some other job[s].]
6280  18e4  08/25 15:52:20 173730 1-# [DM_BASE    ] Going to check whether the mount should be retried for the above mediamanager error
6280  18e4  08/25 15:52:20 173730 1-# [DM_BASE    ] The mount will be retried for the MediaManager error [803] after sleeping for [120] seconds.
6280  18e4  08/25 15:52:20 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 15:52:20 173730 1-# [DM_BASE    ] Setting the job state to waiting
6280  18e4  08/25 15:54:20 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 15:54:20 173730 1-# [DM_BASE    ] Setting the job state to running
6280  18e4  08/25 15:54:20 173730 1-# [DM_BASE    ] Going to retry the Restore Mount.
6280  18e4  08/25 15:54:22 173730 1-# [DM_BASE    ] **ERROR** reserveMountVol Failed VolumeId = 29833 MA hostName- commvault-drp.da.shf.gob.mxClientName - commvault-drp MediaManager returned error [803], errorString [The medium is already reserved by some other job[s].]
6280  18e4  08/25 15:54:22 173730 1-# [DM_BASE    ] Going to check whether the mount should be retried for the above mediamanager error
6280  18e4  08/25 15:54:22 173730 1-# [DM_BASE    ] The mount will be retried for the MediaManager error [803] after sleeping for [120] seconds.
6280  18e4  08/25 15:54:22 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 15:54:22 173730 1-# [DM_BASE    ] Setting the job state to waiting
6280  18e4  08/25 15:56:22 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 15:56:22 173730 1-# [DM_BASE    ] Setting the job state to running
6280  18e4  08/25 15:56:22 173730 1-# [DM_BASE    ] Going to retry the Restore Mount.
6280  18e4  08/25 15:56:24 173730 1-# [DM_BASE    ] **ERROR** reserveMountVol Failed VolumeId = 29833 MA hostName- commvault-drp.da.shf.gob.mxClientName - commvault-drp MediaManager returned error [803], errorString [The medium is already reserved by some other job[s].]
6280  18e4  08/25 15:56:24 173730 1-# [DM_BASE    ] Going to check whether the mount should be retried for the above mediamanager error
6280  18e4  08/25 15:56:24 173730 1-# [DM_BASE    ] The mount will be retried for the MediaManager error [803] after sleeping for [120] seconds.
6280  18e4  08/25 15:56:24 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 15:56:24 173730 1-# [DM_BASE    ] Setting the job state to waiting
6280  270   08/25 15:56:36 ------ CvSearchEngineOperation::TaggerThread() - Search engine is not installed. Nothing to do.
6280  72c   08/25 15:56:36 ###### CvSearchTask::populateAllNicIpaddressToCS() - Client [COMMVAULT-DRP] ipAddress is [192.168.105.64,::1,]
6280  72c   08/25 15:56:36 ------ CvSearchTask::CVEnableAnalyticsAccessControl() - Analytics package is not Installed.
6280  72c   08/25 15:56:36 ###### CvSearchTask::CVSyncContentAnalyzerInfo() - In function CVSyncContentAnalyzerInfo.
6280  72c   08/25 15:56:36 ------ CvSearchTask::CVSyncContentAnalyzerInfo() - Content Analyzer package is not Installed.
6280  74c   08/25 15:56:36 ###### TPool [CVDMessageHandler]. Ser# [1] Tot [8], Pend [0], Comp [8], Max Par [3], Avg Work Time [134.84 ms], Avg Wait Time [502.58 us]
6280  74c   08/25 15:56:36 ###### TPool [IOCPServerPool_JobControlCVD]. Ser# [1] Tot [28], Pend [28], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
6280  74c   08/25 15:56:36 ###### TPool [IOCPServerPool_CVD]. Ser# [1] Tot [28], Pend [28], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
6280  74c   08/25 15:56:36 ###### TPool [IOCPServerPool_SysMonEventSink]. Ser# [1] Tot [28], Pend [28], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
6280  74c   08/25 15:56:36 ###### TPool [SdtHeadThPool]. Tot [0], Pend [0], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
6280  72c   08/25 15:56:37 ###### GetRootFolders() - AllUsersProfileDirectory - [C:\ProgramData]
6280  1894  08/25 15:56:37 ###### CVClientPerformanceHistory::sendFileToCS() - Request to send file:[1661460997_PerfLog_System-1.2_14719194173747207366.csv] from source location:[C:\Program Files\Commvault\ContentStore\Base\Temp] to destination directory:[C:\Program Files\Commvault\ContentStore\Base\Temp\ResourceMonitor\40] on Commserver.
6280  1894  08/25 15:56:37 ###### CVClientPerformanceHistory::sendFileToCS() - Sent file [1661460997_PerfLog_System-1.2_14719194173747207366.csv] to Commserver
6280  f58   08/25 15:56:38 ###### CCVIOMonitorLib::MonitorThreadStatic(568) - Total time spent in Anomaly detection: 0.002013
6280  f58   08/25 15:56:38 ###### CCVIOMonitorLib::MonitorThreadStatic(569) - Time spent in Anomaly detection algorithm: 0.000000
6280  584   08/25 15:56:55 173730 2-# [FSRESTHEAD ] Stats: AppTy 106, AF 2, Seeks 0/2/6, WrkItms 7, MsgsRcvd 21, QLen 13, LstMsg CLOSE_ARCHIVE_AND_REL_VOL
6280  584   08/25 15:56:55 173730 2-# [FSRESTHEAD ] Stats: [AllocBuf Time] Exp Avg [0.00], Total Avg [0.00], Total Time [0.00], Total Count [52]
6280  584   08/25 15:56:55 173730 2-# [FSRESTHEAD ] Stats: [AllocBuf Speed] Curr Avg [24399.13] MB/Sec, Bytes [3405792]; Total Avg [24399.13] MB/Sec, Bytes [3405792]
6280  584   08/25 15:56:55 173730 2-# [FSRESTHEAD ] Stats: [MediaRead Time] Exp Avg [0.00], Total Avg [0.00], Total Time [0.00], Total Count [52]
6280  584   08/25 15:56:55 173730 2-# [FSRESTHEAD ] Stats: [MediaRead Speed] Curr Avg [189.47] MB/Sec, Bytes [612909]; Total Avg [189.47] MB/Sec, Bytes [612909]
6280  584   08/25 15:56:55 ###### [FSRESTHEAD ] CSSrv::ChkState: Clnt [commvault-shf], JobId [0], Rdr has not progressed.
6280  21a8  08/25 15:56:57 ###### CFolderIOInfoWriter::PruneRecordsOlderThan(161) - Pruning successful, ClientId=[40], PruneTime=[2022/07/26 20:56:57.333767Z (1658869017)]
6280  21a8  08/25 15:56:57 ###### CFolderLevelIOInfoWriter::PruneRecordsOlderThan(681) - Pruning successful, ClientId=[40], PruneTime=[2022/08/18 20:56:57.333767Z (1660856217)]
6280  18e4  08/25 15:58:24 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 15:58:24 173730 1-# [DM_BASE    ] Setting the job state to running
6280  18e4  08/25 15:58:24 173730 1-# [DM_BASE    ] Going to retry the Restore Mount.
6280  18e4  08/25 15:58:27 173730 1-# [DM_BASE    ] **ERROR** reserveMountVol Failed VolumeId = 29833 MA hostName- commvault-drp.da.shf.gob.mxClientName - commvault-drp MediaManager returned error [803], errorString [The medium is already reserved by some other job[s].]
6280  18e4  08/25 15:58:27 173730 1-# [DM_BASE    ] Going to check whether the mount should be retried for the above mediamanager error
6280  18e4  08/25 15:58:27 173730 1-# [DM_BASE    ] The mount will be retried for the MediaManager error [803] after sleeping for [120] seconds.
6280  18e4  08/25 15:58:27 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 15:58:27 173730 1-# [DM_BASE    ] Setting the job state to waiting
6280  270   08/25 16:00:15 ###### CvProcess::StartProcessUnicode() - Preparing to launch process: <C:\Program Files\Commvault\ContentStore\Base\ifind.exe>. Priority: <Normal>. Value: <32> creational flag <8>.
6280  270   08/25 16:00:15 ###### [CVD        ] Remote Command Request from remotehost = <10.10.165.221>, RemoteClient = <commvault-shf>, RemoteIP(Sock) = <10.10.165.221>. Launched Process: <ifind.exe -j 173753 -a 2:47 -t 1 -d commvault-drp.da.shf.gob.mx*commvault-drp*8400 -r 1661374811 -ab 0 -i 1 -cs commvault-shf -s "DDBBackup"  -jt 173753:4:1:0:38472  -systemFiles  -mountPath  -seb  -lf 173606 -li 0 -ls 0  -attrEx 0  -cn commvault-drp -vm Instance001>. Pid=6728
6280  18e4  08/25 16:00:27 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 16:00:27 173730 1-# [DM_BASE    ] Setting the job state to running
6280  18e4  08/25 16:00:27 173730 1-# [DM_BASE    ] Going to retry the Restore Mount.
6280  270   08/25 16:00:30 ###### [CVD        ] Submitting thread start request to launch service for App: [cvjobreplicatorods]
6280  1424  08/25 16:00:30 ###### [CVD        ] Launching CVODS.exe, Args [-svcname CVODS_cvjobreplicatorods_commvault-drp_1 -appname CVJobReplicatorODS ] on [commvault-drp.da.shf.gob.mx*commvault-drp*8400]
6280  270   08/25 16:00:30 ###### CvProcess::StartProcessUnicode() - Preparing to launch process: <C:\Program Files\Commvault\ContentStore\Base\CVODS.exe>. Priority: <Normal>. Value: <32> creational flag <8>.
6280  270   08/25 16:00:30 ###### [CVD        ] Remote Command Request from remotehost = <commvault-drp.da.shf.gob.mx>, RemoteClient = <commvault-drp>, RemoteIP(Sock) = <127.0.0.1>. Launched Process: <CVODS.exe -svcname CVODS_cvjobreplicatorods_commvault-drp_1 -appname CVJobReplicatorODS  -cn commvault-drp cvshost:commvault-drp.da.shf.gob.mx*commvault-drp cvsport:50728:0 cvsmyplatform:2 cvsremoteplatform:4 -vm Instance001>. Pid=6984
6280  18e4  08/25 16:00:30 173730 1-# [DM_BASE    ] **ERROR** reserveMountVol Failed VolumeId = 29833 MA hostName- commvault-drp.da.shf.gob.mxClientName - commvault-drp MediaManager returned error [803], errorString [The medium is already reserved by some other job[s].]
6280  18e4  08/25 16:00:30 173730 1-# [DM_BASE    ] Going to check whether the mount should be retried for the above mediamanager error
6280  18e4  08/25 16:00:30 173730 1-# [DM_BASE    ] The mount will be retried for the MediaManager error [803] after sleeping for [120] seconds.
6280  18e4  08/25 16:00:30 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 16:00:30 173730 1-# [DM_BASE    ] Setting the job state to waiting
6280  1424  08/25 16:00:30 ###### [CVD        ] Successfully launched on demand service [CVODS_cvjobreplicatorods_commvault-drp_1] and submitted job request, Unique id is [89070181-16F2-4099-992E-36F1A305210A]
6280  74c   08/25 16:01:36 ###### TPool [CVDMessageHandler]. Ser# [0] Tot [6], Pend [0], Comp [6], Max Par [1], Avg Work Time [110.34 ms], Avg Wait Time [80.29 us]
6280  74c   08/25 16:01:36 ###### TPool [CVDMessageHandler]. Ser# [1] Tot [7], Pend [0], Comp [7], Max Par [3], Avg Work Time [17.98 ms], Avg Wait Time [903.91 us]
6280  74c   08/25 16:01:36 ###### TPool [IOCPServerPool_JobControlCVD]. Ser# [1] Tot [28], Pend [28], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
6280  74c   08/25 16:01:36 ###### TPool [IOCPServerPool_CVD]. Ser# [1] Tot [28], Pend [28], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
6280  74c   08/25 16:01:36 ###### TPool [CVD]. Ser# [0] Tot [3], Pend [0], Comp [3], Max Par [1], Avg Work Time [29.32 us], Avg Wait Time [82.23 us]
6280  74c   08/25 16:01:36 ###### TPool [CVD]. Ser# [1] Tot [3], Pend [0], Comp [3], Max Par [1], Avg Work Time [31.19 us], Avg Wait Time [83.47 us]
6280  74c   08/25 16:01:36 ###### TPool [IOCPServerPool_SysMonEventSink]. Ser# [1] Tot [28], Pend [28], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
6280  74c   08/25 16:01:36 ###### TPool [cvjobreplicatorods]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [772.49 ms], Avg Wait Time [1.79 ms]
6280  74c   08/25 16:01:36 ###### TPool [SdtHeadThPool]. Tot [0], Pend [0], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
6280  270   08/25 16:01:37 ###### GetRootFolders() - AllUsersProfileDirectory - [C:\ProgramData]
6280  f58   08/25 16:01:38 ###### CCVIOMonitorLib::MonitorThreadStatic(568) - Total time spent in Anomaly detection: 0.002090
6280  f58   08/25 16:01:38 ###### CCVIOMonitorLib::MonitorThreadStatic(569) - Time spent in Anomaly detection algorithm: 0.000000
6280  21a8  08/25 16:02:00 ###### CFolderIOInfoWriter::PruneRecordsOlderThan(161) - Pruning successful, ClientId=[40], PruneTime=[2022/07/26 21:02:00.574082Z (1658869320)]
6280  21a8  08/25 16:02:00 ###### CFolderLevelIOInfoWriter::PruneRecordsOlderThan(681) - Pruning successful, ClientId=[40], PruneTime=[2022/08/18 21:02:00.574082Z (1660856520)]
6280  18e4  08/25 16:02:30 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 16:02:30 173730 1-# [DM_BASE    ] Setting the job state to running
6280  18e4  08/25 16:02:30 173730 1-# [DM_BASE    ] Going to retry the Restore Mount.
6280  18e4  08/25 16:02:32 173730 1-# [DM_BASE    ] **ERROR** reserveMountVol Failed VolumeId = 29833 MA hostName- commvault-drp.da.shf.gob.mxClientName - commvault-drp MediaManager returned error [803], errorString [The medium is already reserved by some other job[s].]
6280  18e4  08/25 16:02:32 173730 1-# [DM_BASE    ] Going to check whether the mount should be retried for the above mediamanager error
6280  18e4  08/25 16:02:32 173730 1-# [DM_BASE    ] The mount will be retried for the MediaManager error [803] after sleeping for [120] seconds.
6280  18e4  08/25 16:02:32 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 16:02:32 173730 1-# [DM_BASE    ] Setting the job state to waiting
6280  270   08/25 16:04:08 ###### CvProcess::StartProcessUnicode() - Preparing to launch process: <C:\Program Files\Commvault\ContentStore\Base\vsrst.exe>. Priority: <Normal>. Value: <32> creational flag <8>.
6280  270   08/25 16:04:08 ###### [CVD        ] Remote Command Request from remotehost = <commvault-shf.da.shf.gob.mx>, RemoteClient = <commvault-shf>, RemoteIP(Sock) = <10.10.165.221>. Launched Process: <vsrst -j 173734  -cn commvault-drp -vm Instance001>. Pid=2980
6280  18e4  08/25 16:04:32 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 16:04:32 173730 1-# [DM_BASE    ] Setting the job state to running
6280  18e4  08/25 16:04:32 173730 1-# [DM_BASE    ] Going to retry the Restore Mount.
6280  18e4  08/25 16:04:34 173730 1-# [DM_BASE    ] **ERROR** reserveMountVol Failed VolumeId = 29833 MA hostName- commvault-drp.da.shf.gob.mxClientName - commvault-drp MediaManager returned error [803], errorString [The medium is already reserved by some other job[s].]
6280  18e4  08/25 16:04:34 173730 1-# [DM_BASE    ] Going to check whether the mount should be retried for the above mediamanager error
6280  18e4  08/25 16:04:34 173730 1-# [DM_BASE    ] The mount will be retried for the MediaManager error [803] after sleeping for [120] seconds.
6280  18e4  08/25 16:04:34 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 16:04:34 173730 1-# [DM_BASE    ] Setting the job state to waiting
6280  18e4  08/25 16:06:34 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 16:06:34 173730 1-# [DM_BASE    ] Setting the job state to running
6280  18e4  08/25 16:06:34 173730 1-# [DM_BASE    ] Going to retry the Restore Mount.
6280  74c   08/25 16:06:36 ###### TPool [CVDMessageHandler]. Ser# [0] Tot [2], Pend [0], Comp [2], Max Par [1], Avg Work Time [2.91 ms], Avg Wait Time [96.12 us]
6280  74c   08/25 16:06:36 ###### TPool [CVDMessageHandler]. Ser# [1] Tot [7], Pend [1], Comp [6], Max Par [2], Avg Work Time [9.51 ms], Avg Wait Time [818.35 us]
6280  74c   08/25 16:06:36 ###### TPool [IOCPServerPool_JobControlCVD]. Ser# [1] Tot [28], Pend [28], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
6280  74c   08/25 16:06:36 ###### TPool [IOCPServerPool_CVD]. Ser# [1] Tot [28], Pend [28], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
6280  74c   08/25 16:06:36 ###### TPool [CVD]. Ser# [0] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [32.58 us], Avg Wait Time [85.18 us]
6280  74c   08/25 16:06:36 ###### TPool [CVD]. Ser# [1] Tot [1], Pend [0], Comp [1], Max Par [1], Avg Work Time [37.70 us], Avg Wait Time [46.55 us]
6280  74c   08/25 16:06:36 ###### TPool [IOCPServerPool_SysMonEventSink]. Ser# [1] Tot [28], Pend [28], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
6280  74c   08/25 16:06:36 ###### TPool [SdtHeadThPool]. Tot [0], Pend [0], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
6280  18e4  08/25 16:06:36 173730 1-# [DM_BASE    ] **ERROR** reserveMountVol Failed VolumeId = 29833 MA hostName- commvault-drp.da.shf.gob.mxClientName - commvault-drp MediaManager returned error [803], errorString [The medium is already reserved by some other job[s].]
6280  18e4  08/25 16:06:36 173730 1-# [DM_BASE    ] Going to check whether the mount should be retried for the above mediamanager error
6280  18e4  08/25 16:06:36 173730 1-# [DM_BASE    ] The mount will be retried for the MediaManager error [803] after sleeping for [120] seconds.
6280  18e4  08/25 16:06:36 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 16:06:36 173730 1-# [DM_BASE    ] Setting the job state to waiting
6280  1894  08/25 16:06:37 ###### IndexCacheCleanUpV2: Starting index cache cleanup thread
6280  1894  08/25 16:06:37 ###### getMyHostName_SpaceCheck() - ERROR: cannot determine mangled hostname for 'commvault-drp'
6280  1894  08/25 16:06:37 ###### IndexCacheCleanUpV2: failed to submit task. err [0xECCC0016:{CVOnDemandSvcClient::SubmitTask(43)/ErrNo.22.(Invalid argument)-mangled hostname and/or application name is empty}]
6280  1894  08/25 16:06:37 ------ launchCleanupService() - Failed to attach to CVD(IDXMessageHandler) on []
6280  1894  08/25 16:06:37 ------ IndexCacheMaintenance() - Regular cleanup skipped or failed: 0x80070057:{CCvNetwork::Attach_RemoteDLL(1419)} + {CCvNetwork::DemangleHostNameToComps(4846)/W32.87.(The parameter is incorrect. (ERROR_INVALID_PARAMETER.87))-Invalid mangled host name:[] passed. Please use mangled host name.}
6280  1894  08/25 16:06:37 ------ IndexCacheMaintenance() - Index cache for client [commvault-drp] is using 126786 MB. Location is [F:\Index].
6280  270   08/25 16:06:37 ###### GetRootFolders() - AllUsersProfileDirectory - [C:\ProgramData]
6280  1f68  08/25 16:06:37 ------ CCVDSpaceCheck::CleanupIdleEventConnections() - Invoking CleanUp Idle Event Connections.
6280  f58   08/25 16:06:38 ###### CCVIOMonitorLib::MonitorThreadStatic(568) - Total time spent in Anomaly detection: 0.001942
6280  f58   08/25 16:06:38 ###### CCVIOMonitorLib::MonitorThreadStatic(569) - Time spent in Anomaly detection algorithm: 0.000000
6280  584   08/25 16:06:55 173730 2-# [FSRESTHEAD ] Stats: AppTy 106, AF 2, Seeks 0/2/7, WrkItms 7, MsgsRcvd 24, QLen 16, LstMsg SEEK_TO_OFFSET
6280  584   08/25 16:06:55 173730 2-# [FSRESTHEAD ] Stats: [CtrlCh Idle Time] Exp Avg [0.04], Total Avg [0.04], Total Time [0.18], Total Count [5]
6280  584   08/25 16:06:55 173730 2-# [FSRESTHEAD ] Stats: [Seek Time] Exp Avg [301.05], Total Avg [301.05], Total Time [602.10], Total Count [2]
6280  584   08/25 16:06:55 173730 2-# [FSRESTHEAD ] Stats: [AllocBuf Time] Exp Avg [0.00], Total Avg [0.00], Total Time [0.00], Total Count [52]
6280  584   08/25 16:06:55 173730 2-# [FSRESTHEAD ] Stats: [AllocBuf Speed] Curr Avg [24399.13] MB/Sec, Bytes [3405792]; Total Avg [24399.13] MB/Sec, Bytes [3405792]
6280  584   08/25 16:06:55 173730 2-# [FSRESTHEAD ] Stats: [MediaRead Time] Exp Avg [0.00], Total Avg [0.00], Total Time [0.00], Total Count [52]
6280  584   08/25 16:06:55 173730 2-# [FSRESTHEAD ] Stats: [MediaRead Speed] Curr Avg [189.47] MB/Sec, Bytes [612909]; Total Avg [189.47] MB/Sec, Bytes [612909]
6280  584   08/25 16:06:55 ###### [FSRESTHEAD ] CSSrv::ChkState: Clnt [commvault-shf], JobId [0], Rdr has not progressed.
6280  21a8  08/25 16:07:00 ###### CFolderIOInfoWriter::PruneRecordsOlderThan(161) - Pruning successful, ClientId=[40], PruneTime=[2022/07/26 21:07:00.660875Z (1658869620)]
6280  21a8  08/25 16:07:00 ###### CFolderLevelIOInfoWriter::PruneRecordsOlderThan(681) - Pruning successful, ClientId=[40], PruneTime=[2022/08/18 21:07:00.660875Z (1660856820)]
6280  18e4  08/25 16:08:36 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 16:08:36 173730 1-# [DM_BASE    ] Setting the job state to running
6280  18e4  08/25 16:08:36 173730 1-# [DM_BASE    ] Going to retry the Restore Mount.
6280  18e4  08/25 16:08:38 173730 1-# [DM_BASE    ] **ERROR** reserveMountVol Failed VolumeId = 29833 MA hostName- commvault-drp.da.shf.gob.mxClientName - commvault-drp MediaManager returned error [803], errorString [The medium is already reserved by some other job[s].]
6280  18e4  08/25 16:08:38 173730 1-# [DM_BASE    ] Going to check whether the mount should be retried for the above mediamanager error
6280  18e4  08/25 16:08:38 173730 1-# [DM_BASE    ] The mount will be retried for the MediaManager error [803] after sleeping for [120] seconds.
6280  18e4  08/25 16:08:38 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 16:08:38 173730 1-# [DM_BASE    ] Setting the job state to waiting
6280  18e4  08/25 16:10:38 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 16:10:38 173730 1-# [DM_BASE    ] Setting the job state to running
6280  18e4  08/25 16:10:38 173730 1-# [DM_BASE    ] Going to retry the Restore Mount.
6280  18e4  08/25 16:10:41 173730 1-# [DM_BASE    ] **ERROR** reserveMountVol Failed VolumeId = 29833 MA hostName- commvault-drp.da.shf.gob.mxClientName - commvault-drp MediaManager returned error [803], errorString [The medium is already reserved by some other job[s].]
6280  18e4  08/25 16:10:41 173730 1-# [DM_BASE    ] Going to check whether the mount should be retried for the above mediamanager error
6280  18e4  08/25 16:10:41 173730 1-# [DM_BASE    ] The mount will be retried for the MediaManager error [803] after sleeping for [120] seconds.
6280  18e4  08/25 16:10:41 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 16:10:41 173730 1-# [DM_BASE    ] Setting the job state to waiting
6280  74c   08/25 16:11:36 ###### TPool [CVDMessageHandler]. Ser# [1] Tot [7], Pend [0], Comp [7], Max Par [3], Avg Work Time [125.55 ms], Avg Wait Time [592.59 us]
6280  74c   08/25 16:11:36 ###### TPool [IOCPServerPool_JobControlCVD]. Ser# [1] Tot [28], Pend [28], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
6280  74c   08/25 16:11:36 ###### TPool [IOCPServerPool_CVD]. Ser# [1] Tot [28], Pend [28], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
6280  74c   08/25 16:11:36 ###### TPool [IOCPServerPool_SysMonEventSink]. Ser# [1] Tot [28], Pend [28], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
6280  74c   08/25 16:11:36 ###### TPool [SdtHeadThPool]. Tot [0], Pend [0], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
6280  410   08/25 16:11:37 ###### GetRootFolders() - AllUsersProfileDirectory - [C:\ProgramData]
6280  28bc  08/25 16:11:37 ###### CVClientPerformanceHistory::sendFileToCS() - Request to send file:[1661461897_PerfLog_System-1.2_14719194173747207366.csv] from source location:[C:\Program Files\Commvault\ContentStore\Base\Temp] to destination directory:[C:\Program Files\Commvault\ContentStore\Base\Temp\ResourceMonitor\40] on Commserver.
6280  28bc  08/25 16:11:37 ###### CVClientPerformanceHistory::sendFileToCS() - Sent file [1661461897_PerfLog_System-1.2_14719194173747207366.csv] to Commserver
6280  f58   08/25 16:11:38 ###### CCVIOMonitorLib::MonitorThreadStatic(568) - Total time spent in Anomaly detection: 0.002075
6280  f58   08/25 16:11:38 ###### CCVIOMonitorLib::MonitorThreadStatic(569) - Time spent in Anomaly detection algorithm: 0.000000
6280  21a8  08/25 16:12:01 ###### CFolderIOInfoWriter::PruneRecordsOlderThan(161) - Pruning successful, ClientId=[40], PruneTime=[2022/07/26 21:12:01.843901Z (1658869921)]
6280  21a8  08/25 16:12:01 ###### CFolderLevelIOInfoWriter::PruneRecordsOlderThan(681) - Pruning successful, ClientId=[40], PruneTime=[2022/08/18 21:12:01.843901Z (1660857121)]
6280  18e4  08/25 16:12:41 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 16:12:41 173730 1-# [DM_BASE    ] Setting the job state to running
6280  18e4  08/25 16:12:41 173730 1-# [DM_BASE    ] Going to retry the Restore Mount.
6280  18e4  08/25 16:12:43 173730 1-# [DM_BASE    ] **ERROR** reserveMountVol Failed VolumeId = 29833 MA hostName- commvault-drp.da.shf.gob.mxClientName - commvault-drp MediaManager returned error [803], errorString [The medium is already reserved by some other job[s].]
6280  18e4  08/25 16:12:43 173730 1-# [DM_BASE    ] Going to check whether the mount should be retried for the above mediamanager error
6280  18e4  08/25 16:12:43 173730 1-# [DM_BASE    ] The mount will be retried for the MediaManager error [803] after sleeping for [120] seconds.
6280  18e4  08/25 16:12:43 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 16:12:43 173730 1-# [DM_BASE    ] Setting the job state to waiting
6280  18e4  08/25 16:14:43 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 16:14:43 173730 1-# [DM_BASE    ] Setting the job state to running
6280  18e4  08/25 16:14:43 173730 1-# [DM_BASE    ] Going to retry the Restore Mount.
6280  18e4  08/25 16:14:45 173730 1-# [DM_BASE    ] **ERROR** reserveMountVol Failed VolumeId = 29833 MA hostName- commvault-drp.da.shf.gob.mxClientName - commvault-drp MediaManager returned error [803], errorString [The medium is already reserved by some other job[s].]
6280  18e4  08/25 16:14:45 173730 1-# [DM_BASE    ] Going to check whether the mount should be retried for the above mediamanager error
6280  18e4  08/25 16:14:45 173730 1-# [DM_BASE    ] The mount will be retried for the MediaManager error [803] after sleeping for [120] seconds.
6280  18e4  08/25 16:14:45 173730 1-# [DM_BASE    ] Setting the Job Id to the mounting job
6280  18e4  08/25 16:14:45 173730 1-# [DM_BASE    ] Setting the job state to waiting
  • August 25, 2022
I share full log
Jos Meijer
  • August 25, 2022
Can't remember seeing this issue on 11.24.60, I am fairly positive this is a install/registry related issue.
Would be easiest if I could take a look and discuss the issue via a remote session with you on the media agent. If you want to, send me details for a session via a message to my profile. I will be available for the next hour.
Jos Meijer
  • August 26, 2022
Quick recap:
Performed a remote session, identified that there is a problem with the installation of instance001.
Keeps having issues with mangled hostname or service attachment, no matter what is corrected.
Validated that a secondary instance installation does work.
Communication and processes work as expected.
Juan Pablo is now looking at a reinstall of the commvault software for the damaged instance001.
Onno van den Berg
Forum|alt.badge.img+24
@Jos Meijer to the rescue!
You never cease to amaze me, @Jos Meijer !!
Jos Meijer
  • August 26, 2022
I try to help where I can. 🙃
But no celebration yet, reinstall seems to continue to have the same issue.
Need to check the install, but I am starting to wonder if the issue lies within the client object as a secondary instance test was working like a charm.
I’m still impressed!
I unmarked the answer until confirmed.
Jos Meijer
  • August 29, 2022
