Answer
qoperation jobcontrol commandline
  • January 21, 2022
  • 11 replies
  • 1753 views
Hi All,
i searching for an option for the command for the “qoperation jobcontrol” .
I try to set a suspend with auto resume interval option and i can’t find it in the command line documentation.
in the GUI it’s possible and i hope it’s available in command line.
Kind regards,
Best answer by Mike Struening
@christophe , as best as I can tell, the REST API option is the only option.
It’s also a much more powerful overall toolset as well.
Is your concern about mixing up APIs?  Regarding specifying job IDs, let me see if there’s a switch to just cover all running job IDs.
@christophe , I’ll look into this and see if were is an option here, or elsewhere.
Sharing the doc link for anyone following along:
https://documentation.commvault.com/11.26/expert/45282_qoperation_jobcontrol.html
@christophe , I did find the option via REST API:
https://documentation.commvault.com/commvault/v11_sp16/article?p=47664.htm
Let me know if this works for you!
  • January 24, 2022
Hi Mike,
thanks for your reply. My needs is to create a script to suspend all jobs and services in order to reboot the commserve server after windows update.
So in command line i notice that the autoresume option is not available. But in the rest API syntax, i found the “POST MultiJob Operation” who has a option “JOB_SUSPEND_AUTORESUME” but i need to provide jobid’s. there is a option to include all running jobs ?
regards,
  • January 24, 2022
hi Chritophe,
 you can use “qlist job” or API relevant command. I don't like that command list just basic information.
Filip
  • January 24, 2022
hi Chritophe,
Filip
Hi Filip,
thanks, but yes i can use it but i don’t want to use several API only to obtain the -all equivalent command line.
@christophe
You can use following command to suspend all jobs.
QOperation.exe execute -af C:\JobControlXML
We need to save following xml in  C:\JobControlXML
<JobManager_PerformMultiCellJobOpReq message="0">
<processinginstructioninfo>
 <user _type_="13" userId="1" userName="admin"/>
 <locale _type_="66" localeId="0"/>
 </processinginstructioninfo>
 <jobOpReq operationType="0"/>
<assoc>
 <entity _type_="0"/>
 </assoc>
 </JobManager_PerformMultiCellJobOpReq>
If you want to do get the functionality to suspend and auto resume then below XML should be used.
<jobOpReq operationType="6" autoResumeInSec="1200"/>
<assoc>
 </assoc>
  • January 28, 2022
@christophe
<assoc>
 </assoc>
<assoc>
 </assoc>
thanks it’s what i needed. i have a strange behavior, even if i do a qlogin with the admin user i obtain the error “user not logged in”
Welcome. Please let us know the FR.
Hemant
  • January 31, 2022
Hi Mishra,
i have used the second xml file to do a autoresume and it don’t do the resume after the given time (i have set 2min).
regards,
I will get it checked. As a workaround we can use 2 XMLs. First one to suspend all jobs and second one to resume all jobs.
<assoc>
 </assoc>
 <jobOpReq operationType="2"/>
<assoc>
 </assoc>
