Query for temporary assignment of roles/privilege in Commvault
  • Jan 5, 2025 7:14 PM UTC
  • 34 views
Forum|alt.badge.img+5
Is there a way to provide specific permissions/roles in Commvault which will automatically be revoke/expire  after a certain period of time?
Any assistance is appreciated in this query
  • Jan 6, 2025 1:32 AM UTC
Hi ​@mach123 ,
Roles and permissions in the system are feature-based and require manual assignment. Currently, there is no option to automatically de-associate roles or permissions after a specific number of days.
Forum|alt.badge.img+9
Hi ​@mach123
If you are using azure you can consider using PIM. If you are using AD then you can look into this workflow which can update the AD group
https://cloud.commvault.com/webconsole/softwarestore/store.do#!/136/671/28102
​@mach123 i ll reach out to you over DM to see if a specific workflow will help your use case.
