Question Regarding Changing Disaster Recovery
  • July 25, 2022
  • 51 views
Hello, I have a production server with CS that is already binded to DR (which is installed inside VM)
How can i replace the existing DR (Inside VM) to my newly setup DR (Physical Server).
I hope anyone can help, since i wanted to run a restoration drill. and if you have any advice what to do and what not to do during the restoration drill, that will help me. Thanks.
Best answer by Mike Struening
@AmmarHafiy , this should cover what you are looking for:
https://documentation.commvault.com/11.24/essential/105965_reinstalling_standby_commserve_host.html
Let me know if you have any questions!
